Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Punkt MP02 Battery Replacement
Ce dont vous avez besoin
  1. Punkt MP02 Battery Replacement, Battery: étape 1, image 1 de 2 Punkt MP02 Battery Replacement, Battery: étape 1, image 2 de 2
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Punkt MP02 Battery Replacement: étape 2, image 1 de 2 Punkt MP02 Battery Replacement: étape 2, image 2 de 2
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    Demander à FixBot
  3. Punkt MP02 Battery Replacement: étape 3, image 1 de 3 Punkt MP02 Battery Replacement: étape 3, image 2 de 3 Punkt MP02 Battery Replacement: étape 3, image 3 de 3
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    Demander à FixBot
  4. Punkt MP02 Battery Replacement: étape 4, image 1 de 3 Punkt MP02 Battery Replacement: étape 4, image 2 de 3 Punkt MP02 Battery Replacement: étape 4, image 3 de 3
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    Demander à FixBot
  5. Punkt MP02 Battery Replacement: étape 5, image 1 de 2 Punkt MP02 Battery Replacement: étape 5, image 2 de 2
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
    Demander à FixBot
  6. Punkt MP02 Battery Replacement: étape 6, image 1 de 2 Punkt MP02 Battery Replacement: étape 6, image 2 de 2
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
    Demander à FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elias Fischer
Membre depuis le 02/18/26
425 Réputation
3 tutoriels rédigés
Équipe
University of Memphis, Team 1-3, Sneed Spring 2026 Membre de l'équipe University of Memphis, Team 1-3, Sneed Spring 2026
UM-SNEED-S26S1G3
3 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 42
30 derniers jours : 108
Total : 282
