Introduction
If your Razer DeathAdder V3 Pro's Scroll Wheel is unresponsive to input, jumping, or responds incorrectly, you may need to replace the Scroll Wheel Encoder.
For any quick fixes, please visit our troubleshooting guides for the Razer DeathAdder V3 Pro Scroll Wheel Not Responding to Input and Razer DeathAdder V3 Pro Spotty Wired Connection. If these fixes do not resolve your issues, please follow this guide to replace your scroll wheel.
Before you begin the replacement, please make sure that you have unplugged and powered off the device.
Ce dont vous avez besoin
Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
Remove the three 7 mm screws using a Torx T6 screwdriver.
Insert a spudger into the seam between the top and bottom shells.
Gently work around the edges unclipping the internal latches.
Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
Carefully pull the shells apart to unplug the cable in the front.
Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
Unplug the battery from its connection on the right side.
