Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Remove Stuck Disc from Samsung P241
Ce dont vous avez besoin
    1. Remove Stuck Disc from Samsung P241, Top Case: étape 1, image 1 de 2 Remove Stuck Disc from Samsung P241, Top Case: étape 1, image 2 de 2
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Remove Stuck Disc from Samsung P241: étape 2, image 1 de 2 Remove Stuck Disc from Samsung P241: étape 2, image 2 de 2
      • Pull the top cover towards you until you can lift it up and off.
      Demander à FixBot
    1. Remove Stuck Disc from Samsung P241, Remove Stuck Disc from Samsung P241: étape 3, image 1 de 1
      • After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
      Demander à FixBot
    2. Remove Stuck Disc from Samsung P241: étape 4, image 1 de 1
      • Locate the four rectangular holes in the top of the black plastic disc drive.
      Demander à FixBot
    3. Remove Stuck Disc from Samsung P241: étape 5, image 1 de 2 Remove Stuck Disc from Samsung P241: étape 5, image 2 de 2
      • You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
      Demander à FixBot
    4. Remove Stuck Disc from Samsung P241: étape 6, image 1 de 1
      • Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
      • You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
      Demander à FixBot
    5. Remove Stuck Disc from Samsung P241: étape 7, image 1 de 1
      • Now repeat this process, unclipping the catches on the other side.
      Demander à FixBot
    6. Remove Stuck Disc from Samsung P241: étape 8, image 1 de 3 Remove Stuck Disc from Samsung P241: étape 8, image 2 de 3 Remove Stuck Disc from Samsung P241: étape 8, image 3 de 3
      • You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
      Demander à FixBot
Lawrence Smith
Membre depuis le 01/11/11
126 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-7, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 membres
81 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 26
30 derniers jours : 110
Total : 4,688
