Aller au contenu principal
Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010
Ce dont vous avez besoin
  1. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010, Écran complet: étape 4, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur de la nappe du caisson de basse/du haut-parleur droit pour le débrancher de sa prise sur la carte mère.
    • Faites levier sous les fils.
    Mine had a small piece of insulating material on top of the connector. By removing that first, I could then pry up the connector with less stress on the cable.
    istlota - Réponse
    Great tip! Thanks.
    juliet - Réponse
  5. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 5, image 1 de 1
    • Déconnectez la nappe de la caméra en tirant l'extrémité mâle tout droit hors de la prise.
    • Assurez-vous de tirer sur le connecteur parallèlement à la surface de la carte mère, en direction du lecteur optique et non vers le haut.
  6. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 6, image 1 de 1
    • Dégagez le câble de données de la caméra de la rainure dans le lecteur optique.
    for easy dismantle, just remove 2 screw of subwoofer
    Mohamad Faizal Sharudin - Réponse
  7. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 7, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 7, image 2 de 2
    • Dévissez les vis suivantes :
    • Deux vis cruciformes de 10 mm
    • Une vis cruciforme de 3,8 mm
    • Faites glisser la fixation du câble de la caméra hors de son emplacement sous le caisson de basse et ôtez-la de l'ordinateur.
  8. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 8, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 8, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 8, image 3 de 3
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le connecteur du câble de données de l'écran tout droit hors de sa prise.
    • Veillez à tirer le connecteur hors de sa prise et non vers le haut.
  9. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 9, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 9, image 2 de 2
    • Dévissez les deux vis suivantes, attachant la fixation du câble de données de l'écran au boîtier supérieur :
    • Une vis cruciforme de 8,6 mm.
    • Une vis cruciforme de 5,6 mm.
    • Ôtez la fixation du câble de données de l'écran du boîtier supérieur.
  10. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 10, image 1 de 1
    • Si présent, ôtez le petit morceau de bande adhésive en mousse fixé sur les vis de l'écran à côté du câble de données de l'écran.
  11. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 11, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 11, image 2 de 2
    • Dévissez les deux vis extérieures Torx T8 de 6,5 mm fixant chacune des deux fixations de l'écran au boîtier supérieur (4 vis au total).
    You may have to lift/remove a foam tape on the left side as well
    Sebastien CHAPUIS - Réponse
  12. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 12, image 1 de 1
    • Ouvrez votre MacBook de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook ouvert sur une table comme sur la photo.
    • Pendant que vous maintenez l'écran et le boîtier supérieur d'une main, dévissez la vis Torx T8 de 6,5 mm de la fixation inférieure de l'écran.
  13. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 13, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier inférieur et donc de les abîmer.
    • Dévissez la dernière vis Torx T8 mm fixant l'écran au boîtier supérieur.
    When reassembling, Careful not to drop your screw, or it may get stuck to the (magnetic) power adapter port. Oops!
    Save yourself some time and don't drop it!
    rowdyferret - Réponse
  14. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 14, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 14, image 2 de 2
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran de sorte que la fixation supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
    Make sure you make a 90 degree angle between the keyboard and the display before taking out the screws. If you have less than a 90, you will never get it apart due to the upper display bracket shape. It has to be at the right angle or it won't come out.
    mastover - Réponse
    I place it over keyboard side down hanging over a table. This way I know it's at 90 degrees and it also makes it easier to take it off.
    Nick - Réponse
  15. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2010: étape 15, image 1 de 1
    • Soulevez et éloignez l'écran du boîtier supérieur en veillant à ce que aucune fixation ni aucune nappe ne reste accrochée.
    As mentioned in the previous step, place it keyboard side down with the edge hanging over a table. This way it's at 90 degrees and it makes it easier to align and get the screws in.
    Josh - Réponse
Pour remonter votre ordinateur, suivez les instructions en sens inverse.
78 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
Awesome guide!! Thank you so much for walking me through this. It was surprisingly easy. Only took me about 30 min to do. Best Buy Canada quoted me $900 to do this repair. Total cost of tools from iFixit and parts from eBay... $280 :) THANK YOU IFIXIT!!!!!
spenczoid - Réponse
Thanks for the guide, it was spot on. I dropped my beloved MacBook Pro and it cracked the display. Following the guide was a snap even for my old eyes, the ability to make the pictures full screen is great.
jackpollard - Réponse
I found a used complete display unit for sale on ebay. Delivered 50$ and half an hour of work and am up and have a lovely MBP 13 inch mid 2010. Many thanks for the useful and detailed guide.
keithp198 - Réponse
Had the standard problem with a loose screen on a MacBook Pro 13in 2010. Followed the guide which is very clear and got to the screws which I could then tighten. Reassembled and on booting could hear the fan but no display aside from a few flashes. Rechecked the screen data cable connection which was slightly mis-aligned. corrected it and it worked fine. That connection is very sensitive!
Saved me $900 quoted by the Macstore - 90 mins work on my own and a few grey hairs. A glass of red wine helps.
Norbert - Réponse
Just followed the steps and I successfully reinstalled a new screen/lid assembly. The only problem being was step 4. When gently (underline gently) removed the audio cable, all of the pins fractured and remained in the board so now my onboard audio is highly limited. I have to ask why was that step necessary as the removal/reinstall would have been completely possible without step 4. Greg
gdmenginc - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 104
Total : 85,185
