Aller au contenu principal
Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010
Ce dont vous avez besoin
  1. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les dix vis suivantes qui fixent le boîtier inférieur au boîtier supérieur :
    • Trois vis cruciformes de 13,5 mm (14,1 mm).
    • Sept vis cruciformes de s 3 mm.
    • Quand vous les dévissez, adaptez la position du tournevis à la légère inclinaison des vis par rapport au boîtier. Il faudra les revisser de la même façon.
    Step 1 (technically step 9 - replacing the base plate) Apparently one of my screws was a micron or two smaller than the others. This screw belongs to the hole above the optical drive, which is also apparently a couple of microns smaller than the others. It took seven attempts to figure which screw had originally been in that hole; all the other screws were too large, but fitted perfectly everywhere else.
    Bizarre much?
    Will - Réponse
    It might be a matter of how the screws are driven in, and not that they're slightly different sizes. When I reassembled my MacBook, a couple of the screws, including the one over the optical drive you mention, were hard to drive in and jutted up a little bit instead of sitting entirely flush. Swapping screws didn't help. The solution was to unscrew them and drive them in at a bit of an angle - perpendicular to the slightly curved surface of the back plate where the screw holes were, instead of fully vertical with respect to the ground the Macbook is sitting on. Doing it that way, the screws were easier to drive in and they all ended up flush in their holes. Didn't matter which screws they were. (I swapped a few around just to check after reading this.)
    Andrew Janke -
    I had no such screw issues. Either there are differences in manufacturing lots or I just got incredibly lucky during reassembly!
    xtophr -
    I discovered a great way of organizing the screws. I used an ice cube tray and added the screws in order, keeping the different kinds together. So when it came to reversing the steps, the screw order was an added control step to returning everything in its place.
    leonie - Réponse
    Great advise! Love it! :)
    Ririds -
    I used to do that and that worked really great until I bumped it by accident and the entire tray went on the rug! I spent the next day sorting things out.
    Now I use these:
    http://www.sciplus.com/p/50-114-CLEAR-PL...
    The lower ones 50 to a package. I mark them w/ blue tape. Often if it's part like the fans, or the optical drive I'll tape the screws into/near the holes where they belong. I did this a lot especially w/ the bottom screws from MBPs until I'd done so many I knew exactly where the longer ones went.
    Richard Sato -
    I wrapped the screws in a piece of blue masking tape and wrote the number on the little pouch I made. Then I stuck the blue tape pouches on the underside of the case bottom in order.
    Roscoe -
    I take double-sided tape, put that on a piece of paper, stick the crews to that, and label them.
    jelimoore -
    Best I've found is a bead sorting tray. They're like $5 at Wal-Mart and they have a lid that seals up and won't let them jump between containers.
    maccentric -
    I take a sheet of paper, pierce the screws through the paper, take a pen and box the screws and write out what step they belong to.
    Nils -
    @Will, in my case I had the same result as you did. As a reminder to myself the next time I need to open the computer, I put a dot of white paint on those two screw's head and a very, very thin ring of white on the very edge of each hole, that way I'll know they go into those two holes.
    Roger - Réponse
    Actually the four screws on the bottom were not threaded all the way up. I didn't check to see if the thread gauge was the same on them, but it wasn't until I had about four screws out (I didn't take them out in the order that the bottom all came out first) that I noticed a difference. I then took out the rest of the bottom ones to see if they matched the two that were already out that weren't threaded to the top. They did. So I went under the assumption that those were all bottom screws and when I put it back together everything went fine with no resistance.
    So there are three types of screws: Four for the bottom, three long ones as indicated and three others that might be slightly smaller than the bottom ones.
    wresnick - Réponse
    Hi,
    Although its more than a year since your contribution, I thought you might be amused to know that it is not just that the screws go in more easily when at an angle, Apple actually drilled and tapped the holes at a 15% angle. I too had tried to drive them in straight. An Apple "genius" - I was in for something else - clarified the design for me. It was done so that the screws lay flush on the angled part of the lower case. Nice design, but since Apple encourages DIY memory and drive changes, they could have mentioned this little ... trap.
    H Stahl -
    MacBookPro8,2
    Intel Core i7, 2,2 GHz, RAM 16 GB
    Mountain Lion
    May someone help me?
    I have installed the second drive with ssd 840 evo, but when I try to copy the file from the new drive to the main hd this in not allowed (errore -36)
    Piero - Réponse
    To my knowledge you can't transfer a single file more than 4gb. I advise compressing to a bunch of rars to split the file size and moving them individually
    1982sketcher -
    Hey everyone, here's the very best way to PERFECTLY organize your screws AND keep track of the order of the procedure: Get a piece of plain corrugated cardboard and a pen (I like using a Sharpie). For EACH step of the disassembly, draw a simple diagram of the layout of the computer on the piece of cardboard, with dots or Xs where the screws are located. Right after you remove each screw from the computer, poke a hole in the cardboard in its corresponding diagram position with your screwdriver and place the screw in that hole. If there are other non-screw related parts to be removed, you can add notes below each step diagram to remind you of where they go or how they should be placed. This cardboard method is great not only because your screws will not go flying or get mixed up by accident if bumped, but each screw goes EXACTLY back where it came from and you can keep the cardboard as a template for future use if necessary!
    - zerø K
    zeroK - Réponse
    These instructions worked great for me. I ordered a replacement battery from Key Power (on Amazon) for my 15" Macbook Pro (mid-2010). Cost was $74 shipped.
    Battery came with 3 different screwdrivers to help with installation. I just needed the one size though, since my 2010 seemed to use all the same size screws.
    Thanks!
    Marcos - Réponse
    During re-assembling (put the screws back in), it is important to note that the 3mm threaded holes are not completely vertical, but bent a little bit such that the hole direction is rectangular to the tapered surface. The force of the screwdriver must point towards the direction of the hole. Otherwise the screw gets jammed
    kusi - Réponse
    There is a FOOLPROOF WAY TO ORGANIZE ALL SCREWS and other parts removed.
    Print the repair guide.
    Yes, the actual photo of the bottom of the laptop with the circles around the screws.
    When you remove the screw, tape it to the photograph.
    You will tape the screw to the exact location that you just removed it from.
    Same thing with any part you remove.
    splashzoneent - Réponse
    Thanks Splash!!! I used your suggested method, and it was perfect: kept all my screws, and i was able to, very easily, put them back in their correct place. I greatly appreciated your feedback. Thank you for sharing!!
    Tommy Kedar -
    Thank you!!! This worked fabulously - even the I.T. people at my workplace were excited as they never thought to do that before. Replacing the battery took about 10 minutes!
    nclarke36 -
    Worked like a charm! Took less than 20 minutes.
    It's Oct. 2015, and the fan cost me about $10. it was the same brand/model...
    SUNON MG62090V1-Q020-S99 .
    SOME TRICKS -
    1- no T6 screwdriver- was careful using needle nose players to loosen 2 screws protruding up, then use a small phillips to push real hard into the T6 slots, SLOWLY turn , also used a small flat head screwdriver (for eye glass repair) was able to grab thread on T6's, made a small mark with screw driver across the top so I could see when it started to turn.
    2- no spudger -made one; cut a little strip 1/2" x 1 1/2" of plastic. couldn't get it to slide under plug, there's an edge where plug fits. so lifted old fan out, pulled upward on the plug it popped right out with very little effort. I used my home made spudger to push the new plug into place.
    3- download free "Macs Fan Control" This is how I was alerted to the fan not working in the first place. Program shows temperature of all key components in the computer.
    cheers- Durango CO!
    Dgodrummer - Réponse
    Watch the video first, read the entire tutorial and all the comments before you start, and spread a white towel on the floor so you can find screws when you drop them. Watch this first -- http://www.youtube.com/watch?v=qiBxhA29e...
    kevicoll409 - Réponse
    The link above is no longer available.
    Kristina Graham -
    I will be buying a battery from you and using your instructions. I just installed a new CD/DVD using your instructions and 1) I feel like I owe you something and 2) Although more expensive, I have the confidence your battery will work. My current battery is the original with 1399 cycles in 7.2 yrs. A tech buddy had bought me a replacement and I installed it. I had just installed a new OS and the kernel_task went going nuts, using 90% of the CPU. Hours on the phone with Apple did not resolve the issue. On a whim, I put the old battery back in and Voila! But I cannot risk my battery swelling and going south on me. I am also going to buy your installation tools. Yeah, I already have them. But you can never have enough tools…or beer. And you don’t sell beer.
    Pete Banks - Réponse
    The instructions say that I am removing PH00 screws. I found that my MBP, mid ‘12, Retina has pentalobe screws instead!
    jsandersonq - Réponse
    This laptop definitely originally shipped with Phillips screws—but, Apple has been known to replace Phillips screws with pentalobes when one of their devices is brought in for service. Sorry for the rude surprise! Fortunately the correct driver is easy to find nowadays. [Blatant self-promotion alert!] If you support free repair manuals, consider picking one up from iFixit. Good luck!
    Jeff Suovanen -
    Me, too, and it’s plausible that this machine has been serviced by Apple in the past, replacing the screws as Jeff Suovanen suggests.
    iFixit shipped a pentalobe bit with the kit, but it’s too large for the actual screws, so it looks like I now need to get another bit. But what size?
    Jeff’s link is to a driver with a P5 bit, and that page links to a P2 screwdriver, but since I don’t know what size I actually need (and I don’t have a micrometer to hand) I’m reluctant to buy two on spec.
    Norman Gray -
    (The bit in the kit appears to be a P6, so I’m inclined to order a P5 and see what happens)
    Norman Gray -
    You’re using the wrong repair guide. This guide is for the 2012 NON-Retina MBP. You have a Retina MBP. The stock case screws in the 2012 NON-Retina are all Phillips, just as the guide says.
    Steven Wymor -
    To keep track of screws, I used the suggestions above by taping a photo of the lower case to a piece of corrugated cardboard and inserting/taping the screws in place. Also, as some have noted, the screws go back in at a slight angle; they are angled toward the center of the unit.
    Kristina Graham - Réponse
    If your vision, like mine, is getting too fuzzy to be able to distinguish between a tiny Phillips screwdriver and a tiny Tri screwdriver, there’s an easy way. With a Phillips (or a Pozidrive) you can get two opposite wings to reflect the light from a lamp or window straight towards your eye at the same time. With a Tri (or Penta) you can only get one wing to reflect at a time, however much you twiddle it.
    Alan Waller - Réponse
    There’s a very easy way to avoid cross-threading a screw thread, any size.
    Put the screw into its hole and start by turning it gently, slowly BACKWARDS. When you hear a little “Click!” sound, the male thread has just passed the opening in the female thread and is in exactly the right position to enter into it correctly when you start to turn in the correct forward direction.
    Remember, all drivers except hex (Allen key) and TorX need pressure to avoid slipping out and damaging the head. So even when you want to turn it in with LOW moment/torque, keep the CONTACT PRESSURE high.
    The keep the pressure on is on point. In my case once I loosened my first screw I thought I could relief my initial pressure. It was a mistake. I was doing the whole thing very slowly as a precaution. That helped me notice that the Phillips screw driver was sliding up out of the screw head. Not being sure why, I put pressure back on the screw driver until almost all the screw was out of the hole. Once out, I examined closely to find out that the threads have some sort of coating. It looks to me like some kind of locktite. Then I understood the importance of keeping the pressure on all the way through. It made me uneasy having to keep so much pressure on such tiny screws, but I found it was the only way to prevent damage to the “slots” on the heads. Anyway, all of them suffered some degree of damage, but I was able to successfully remove them and reinstall all of them back in their original holes.
    Martin Mejia -
    After reading this page on iFixit several times, I just could not face all the work of replacing the Logic Boards on two MacBookPro 2011s even if I was prepared to pay approx 400 USD (which I wasn’t). Then I read the reviews of a couple of folks who’d stripped down their machines and put their logic boards in the oven and, it worked! I wondered, if I just used my new Steinel Hot Air Tool (heat gun in my language) recently delivered from iFixit, on the logic board in-situ, without removing it? So I removed the battery, hard drive, and RAM and unplugged all the leads I could see WITHOUT removing anything else physically. Then using the 500 degrees set on the gun (setting 2) I ‘played’ the gun over the logic board for about 60 seconds on machine one with the restart problem (plus latterly, not completing start-up). Long story short… it worked! I spent a long time getting the s/w to load, but the commentary is too short to let me relate that part… ping me if I can help you do the same! blackaye@gmail.com
    Ian Black - Réponse
  2. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 2, image 1 de 1
    • En vous servant des deux mains, soulevez le boîtier inférieur au niveau de la fente pour le libérer des deux clips qui le fixent au boîtier supérieur.
    • Retirez le boîtier inférieur et mettez-le de côté.
    What is the maximum amount of RAM that can be installed in this MacBook?
    michael - Réponse
    16 GB is the max
    Bradon Kelley -
    I can’t get the back panel off !! Removed all 10 screws but the panel is still on. Not a quick easy lift like in the picture of videos on youtube what going on…are the hidden screws locking tabs?
    Tachyon - Réponse
    Solved the tabs were hard to get off to the point I thought I was going to bend the back case off before it would let go.
    Tachyon - Réponse
  3. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Batterie: étape 3, image 1 de 1
    • Retirez les deux vis Tri-Point de 7,4 mm par lesquelles la batterie est fixée au boîtier supérieur.
    • Remarque : pour certaines réparations (disque dur, par exemple), le retrait de la batterie n'est pas indispensable, mais permet d'éviter un court-circuit accidentel sur les équipements électroniques de la carte mère. Si vous ne retirez pas la batterie, faites attention, car les composants de la carte mère peuvent être sous tension.
    • Il n'est pas indispensable de retirer la batterie en suivant les étapes 3 à 6 pour remplacer le disque dur. Il est cependant recommandé de retirer toutes les sources d'alimentation des éléments électroniques avant de travailler sur ces derniers.
    A 1/16th flathead screwdriver easily removes the tri-wing screws in this step. I could not find a Y0 Tri-wing driver at any local stores.
    Jon Daniels - Réponse
    I'd like to add that for me, a 1/16th flathead screwdriver did NOT allow me to remove the tri-wing screws holding the battery in place. After several careful attempts, it became obvious I was perilously close to stripping the screw(s), so I abandoned the attempt to unscrew the tri-wing screws with a flathead screwdriver altogether. As it turned out, I didn't need to remove the battery to do what I needed to do (keyboard replacement), but it would have been a whole lot easier had the battery been easily removable.
    dave - Réponse
    The Tri-wing screw driver is impossible to find in retail, amazon and ebay are great bets but they vary wildly in quality... I ordered two, and both were so cheap, and barely got the job done. It could be worth getting it here. When you do get it, make sure you push, the Y0 screws were very tight in my macbook, pressing hard prevents you from stripping the Y screw.
    Abe - Réponse
    I believe they are Y1 screws, no?
    Mark -
    What worked for me was actually a set of needlenose pliers - the heads on those screws aren't flush, they actually stick out enough that it's possible to turn them from the outside. Caused some scuff marks on the finish of the screws but it's not like anyone's going to see them anyway!
    oboewan42 - Réponse
    A tri-wing screwdriver sold as 'for Nintendo Wii' marked 'HFA 360/ x50' did the job. I replaced the screws with standard-head M2x6mm metric screws (M2 = 2 mm thread, 6 mm length of threaded part). Exactly, I took them out of an old hard-disk (with torx head and slightly shorter).
    akronymus - Réponse
    I had a cheap Tri-wing screw driver. The one that comes with the “Newertech“ battery. It did not make the job and it rather damaged the screws. Panic! I decided to buy the screwdriver sold by ifixit, the German one, not the other. At any point did I want more surprises. Yes it’s pretty expensive, but equally useful even with the screws already damaged. Thanks guys!
    Raul Roman - Réponse
  4. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 4, image 1 de 1
    • Avec le bout du doigt, décollez avec soin l'angle de l'étiquette d'avertissement pour accéder à une vis Tri-point cachée.
    • Retirez la dernière vis Tri-point de 7,4 mm par laquelle la batterie est fixée au boîtier supérieur.
    Is removing the battery necessary?
    bname - Réponse
    It is not strictly necessary. As mentioned above, removing the battery is the only way to be sure that no parts of the logic board are electrified. It is very easy to replace the hard drive without removing the battery, but it is safer to remove the battery first.
    Daniel Brauer -
    Note: removing the battery can cause a hitch with OS X 10.9 Mavericks installation to a blank drive, or at least it did for me.
    Disconnecting the battery makes the hardware clock reset to something like Jan 1, 2000. This causes the Mavericks installer to fail its self-check with the error message: "This copy of the Install OS X Mavericks application can't be verified. It may have been corrupted or tampered with during downloading."
    To fix this, you need to open up Terminal from the Utilities menu in the bootable OS X installer environment and use the `date` command to set your Mac's clock back to the correct time before proceeding with the "Install OS X" menu selection, as described here: http://blog.mconserv.net/2013/10/install...
    Andrew Janke - Réponse
    Thanks for that warning, Andrew.
    Max Fenton -
    Happened here too, thanks for the tip!
    Franco Bianchi -
    As a note, my Mid-2010 Unibody Macbook did not have this third screw, just two to remove the battery.
    Max Fenton - Réponse
    Can anyone answer this question. I cannot afford the entire 80 dollar repair kit listed here and the tools needed only list a spunger t6 and a phillips...it appears from some of these comments there are more drivers needed. I am afraid to do this anyway but not having the right tools off the bat will just make things more difficult while waiting for an order to come in...can someone list the exact tools I would need ? Any help would be appreciated...I am ready to order this but want to put in one order....ifixit, can you clear this up perhaps ?
    laurie - Réponse
    One of the most important tool you should get is the head strap magnifier with lighting, it will make your viewing and capable ability much more confident.
    James -
    Taking the battery out is the easiest part once you have the Tri-Wing screwdriver
    Tri-point Y1 Screwdriver
    Tao - Réponse
    And yes, taking the battery out does naturally make the hardware clock reset.... It's easily fixed. See Andrew Janke's comment above.
    It's a small hassle, compared to needing to possibly replace your logic board because a surge from your battery fried it.
    Tao - Réponse
    Ne trouvant pas de tournevis Y1, j'ai utilisé avec succès une pince électrique à bouts fins pour déserrer la vis puis j'ai terminé avec un tournevis plat très fin (1.5x35)
    Ivan Keller - Réponse
    I stripped the Y screw! Arghhhh. Any help ideas?
    erinandjoy - Réponse
    new battery drains at the rate of about 10% a minute. i may have received a faulty one but i wouldn't have bought it if i knew what i know now.
    aozoren - Réponse
    Is this a battery from iFixit?
    Scott Dingle -
  5. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 5, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 5, image 2 de 2
    • Soulevez la batterie en tirant sur la languette d'extraction et dégagez-la du boîtier supérieur.
    • N'essayez pas de retirer complètement la batterie pour le moment.
  6. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 6, image 1 de 1
    • Inclinez la batterie vers l'arrière suffisamment pour accéder au connecteur du câble de la batterie.
    • Débranchez le câble de la batterie de sa prise sur la carte mère et retirez la batterie du boîtier supérieur.
    • Retirez ensuite le connecteur du câble de la batterie au centre de la carte mère.
    • Si vous installer une nouvelle batterie, vous devriez la calibrez :
    • Chargez-la à 100%, puis laissez-la charger encore au moins deux heures. Utilisez votre appareil normalement. Lors de l'avertissement de batterie faible, enregistrez votre travail et laisser votre ordinateur allumé jusqu'à ce qu'il s'éteint à cause d'une batterie vide. Attendez au moins 5 heures, puis rechargez la batterie à 100% sans interruption.
    • Si vous remarquez quelques chose d'inhabituel ou si vous avez des problèmes après l'installation de la nouvelle batterie, il se peut que vous deviez peut-être réinitialiser le SMC de votre MacBook.
    I'm having the same problem as previous commenters: the battery now drains much faster. It's the original factory unit—I only replaced the HD, which is working great.
    Is there something I am missing with the battery reconnection? Maybe it's loose?
    I just want to make sure before I crack open my laptop again.
    cmalec722 - Réponse
    Fast battery drain problems might be due to a corrupted power manager circuit on the logic board. To reset it, remove the battery, press the power button for about 5-10 seconds, then reinstall the battery. I know the problem might have been partly due to removing the battery in the first place, but this is the procedure for resetting what might have gone wrong. It might also help to do a PRAM reset, by holding down Command-Option-P-R at power (not just from a restart), and let the Macbook chime twice after its initial powerup chime.
    johnsawyercjs -
    The spudger works well for detaching the connector.
    skat1140 - Réponse
    I’ve done a few of these and it should be noted this connector is a very firm fit. Using the flat end of the spudger to pry alternately at the protruding sides can be helpful.
    py - Réponse
    Buen tutorial, solo advertir una cosa: los tornillos de la batería (Tri-point), en mi caso estaban muy duros.. atención si se usan destornilladores baratos.. mucho cuidado porque puedes dejar el tornillo imposible de extraer..
    fserranolv - Réponse
  7. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Écran complet: étape 7, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), soulevez délicatement la nappe Airport/Bluetooth pour la débrancher de sa prise sur la carte mère.
  8. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 8, image 1 de 1
    • Tirez le connecteur de la nappe de la caméra tout droit hors de sa prise sur la carte mère.
    • Tirez sur la nappe parallèlement à la surface de la carte mère, vers l'ouverture du lecteur optique.
  9. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 9, image 1 de 1
    • Avec la pointe d'une spatule, débranchez les trois connecteurs d'antenne de la carte AirPort/Bluetooth.
  10. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 10, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 10, image 2 de 2
    • Dégagez les trois câbles d'antenne de leur canal sur le boîtier AirPort/Bluetooth.
    • Dégagez la nappe de la caméra de son canal sur le boîtier AirPort/Bluetooth.
  11. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 11, image 1 de 1
    • Dévissez les deux vis suivantes, fixant le boîtier AirPort/Bluetooth au boîtier supérieur :
    • Une vis cruciforme de 3,8 mm
    • Une vis cruciforme de 8,6 mm
  12. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 12, image 1 de 1
    • Ôtez l'ensemble AirPort/Bluetooth du boîtier supérieur en évitant que les câbles ne restent accrochés.
  13. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 13, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 13, image 2 de 2
    • Dévissez la vis cruciforme de 8,6 mm fixant le support du câble antenne/caméra au boîtier supérieur.
    • Ôtez le support du câble antenne/caméra du boîtier supérieur.
  14. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 14, image 1 de 1
    • Dévissez deux des trois vis Torx T6 de 6 mm fixant le côté droit de l'écran au boîtier supérieur.
    • Nous vous demandons intentionnellement de laisser une des vis fixant l'écran au boîtier supérieur, car cela facilite les étapes suivantes.
  15. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 15, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 15, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 15, image 3 de 3
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et faites-la pivoter vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le connecteur du câble de données de l'écran vers l'arrière pour le débrancher de sa prise sur la carte mère.
    • Ne tirez pas le câble de données de l'écran vers le haut, car la prise est très fragile. Tirez sur la câble parallèlement à la surface de la carte mère.
  16. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 16, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 16, image 2 de 2
    • Dévissez la vis cruciforme de 8,6 mm fixant le support du câble de données de l'écran au boîtier supérieur.
    • Ôtez le support du câble de données de l'écran du boîtier supérieur.
  17. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 17, image 1 de 1
    • Dévissez deux des trois vis Torx T6 de 6 mm fixant le côté gauche de l'écran au boîtier supérieur.
  18. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 18, image 1 de 1
    • Ouvrez votre MacBook Pro de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook Pro ouvert sur une table comme sur la photo.
    • Pendant que vous maintenez l'écran et le boîtier supérieur de la main gauche, dévissez la vis Torx T6 restante de la fixation supérieure de l'écran.
  19. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 19, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier inférieur et donc de les abîmer.
    • Dévissez la dernière vis Torx T6 fixant l'écran au boîtier supérieur.
  20. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 20, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 20, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 20, image 3 de 3
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran de sorte que la fixation supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
    • Soulevez et éloignez l'écran du boîtier supérieur en veillant à ce que aucune fixation ni aucune nappe ne reste accrochée.
  21. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Vitre avant de l'écran: étape 21, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Vitre avant de l'écran: étape 21, image 2 de 2
    • Au cours des étapes suivantes, vous aurez besoin d'une pistolet à air chaud pour ramollir la colle fixant la bordure extérieure noire à l'écran tout le long de la face intérieure de la vitre avant. La zone où la colle a été mise est marquée en rouge sur la seconde photo.
    • Avant de commencer, veillez à nettoyer la vitre avec un chiffon non pelucheux humidifié avec une solution lavante douce ; cela permettra à la ventouse à levier de mieux adhérer et à vous de vérifier plus facilement l'absence de poussière lors du remontage.
    • Réglez le pistolet à air chaud à température basse et commencez à chauffer la bordure extérieure noire, du côté du coin supérieur droit de l'écran.
    • Ne pointez jamais le pistolet sur la bande souple en caoutchouc le long de la vitre. Si vous chauffez le caoutchouc, vous risquez de le faire fondre légèrement et de rendre brillante sa surface matte. Si vous touchez le caoutchouc surchauffé, vous risquez de le déformer définitivement.
    • Pendant que vous chauffez, il est normal qu'une couche de condensation se forme à l'intérieur de la vitre et/ou à l'extérieur de l'écran LCD. Vous pouvez l'enlevez avec du nettoyant pour vitres une fois que la vitre est séparée de l'écran.
    Another caution is needed - the heat gun is capable of discoloring the LCD panel (giving uneven coloration) if it overheats. This is possible on the low setting. Proceed cautiously, heating in increments until the glass releases.
    Alden Stradling - Réponse
    I was wondering the same, is absolutely necessary to disassemble the screen to change the glass? Can I jump to step 21?
    caholzmann - Réponse
    To change just the glass I used a hair dryer it gives off enough heat to do the job. Stand the computer up on its cover with the key board standing up.start at a corner heat the adhesive as you go along. I Put credit cards in as I went along so the adhesive doesn't stick again. take your time . Its easy.
    Robert Lachman - Réponse
  22. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 22, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 22, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 22, image 3 de 3
    Outil utilisé dans cette étape :
    Heavy-Duty Suction Cups (Pair)
    $14.95
    J'achète
    • Une fois que la vitre a été suffisamment chauffée, fixez une ventouse à levier à côté du coin supérieur droit de la vitre.
    • Ne fixez pas la ventouse sur la bande en caoutchouc au bord de la vitre.
    • Si vous utilisez une de nos ventouses, posez-la, la poignée mobile parallèle à la surface de la vitre. Puis, tout en appuyant légèrement la ventouse sur la vitre, relevez la poignée mobile jusqu'à ce qu'elle soit parallèle à l'autre poignée.
    • Soulevez et éloignez lentement et délicatement le coin de la vitre de l'ensemble écran.
    • Si vous arrivez juste à soulever le bord supérieur de l'écran (comme sur la troisième photo), répétez les étapes un et deux jusqu'à ce que le coin de la vitre se soulève.
    Sufficiently heated is a meaningless phrase here. Is it two minutes? Three? Fifteen? An hour? I have tried doing this for increasing amounts of time while avoiding doing damage to the machine, and nothing is working. Sufficient heating needs definition.
    Keith McComb - Réponse
    Hi Keith, the key here is that you want to warm the adhesive that's spread thoroughly behind the masked-black area of the glass around the screen to release, but not put enough heat at the rubber gasket that seals the closed top lid to the base. Too much heat, too soon, will deform the rubber. Too much and you'll never get the glass to release. The 2x that I have done this, however, even with sufficient (and significant) heat, I remember the glass taking a surprising amount of leverage to pull clear. A tactic: using your heat gun warm all the sides of the display from the front, in a circulating/racetrack fashion - about 20 rpm. After 30sec, focus on the left and top sides, seesawing from bottom left, to top left, to top right, and back. Do that at the same pace, about 5-10 passes. Then spend about 10 sec waving over the whole top left corner. That should get enough heat to enough places to help the glass separate to start placing picks, and you can continue to heat the margins as you progress.
    johnkimmel - Réponse
  23. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 23, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 23, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 23, image 3 de 3
    • Soulevez précautionneusement le coin de la vitre de sorte à pouvoir insérer une spatule (spudger) entre elle et l'ensemble écran.
    • Avec l'extrémité plate de la spatule, décollez soigneusement la bande adhésive fixant la vitre à l'écran.
    • Soulevez la vitre de quelques centimètres au-dessus du coin supérieur droit, tout au long du bord supérieur et du bord droit de l'écran.
    Be careful with the spudger and the soft rubber strip around the glass. Since the rubber strip has been heated up by the heat gun, it is easily smushed and deformed by the spudger.
    Rob - Réponse
    Be patient and work slowly or else you will crack the glass like me.
    BillyRachel1 - Réponse
    I can not get the glass to come up despite two tries and dicsoloring the LCD with too much heat. Why can't I get the glass to budge at all?
    bollucks66 - Réponse
    It is better , instead of using the suction cup , to use small flat end spudger . The suction cup should be used first to detach the window from the gasket , not furthermore as it may brake the glass.
    Thierry de Montblanc - Réponse
    I didn’t have large suction cups and the small ones didn’t work for me. Instead, I used an opening tool to pry up the glass slightly and got a guitar pick under it. Then I slowly worked the pick around the top three sides of the glass, heating sections of glue as I went.
    Daniel Arnfield - Réponse
    I’ve managed to do it using hair dryer on max. First corner was though and took a lot of time to lift it. I decided to heat not only a corner but whole length and then it came off. I’ve put so much heat that was afraid I’ve damaged LCD, but it works fine. As BillyRachel1 said: patience is the way. In order to assemble it back I used old glue heated again. It’s easy but takes time.
    Note: Don’t do this at home if you have cats otherwise you going to spend next hour or so trying to remove their fur from between glass and LCD. It’s because they all levitate after using hot air and just wait to stick to the screen again.
    To be honest hardest thing was replacing clutch cover, took me so much time and I eventually cracked it.
    D. K. Labudek - Réponse
  24. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 24, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 24, image 2 de 2
    • Avec un pistolet à air chaud, faites ramollir la colle sous la bordure noire le long du côté droit de la vitre avant.
    • Fixez une ventouse à levier du côté droit de la vitre avant.
    • Soulevez la vitre pendant que vous la séparez du reste de l'ensemble écran avec l'extrémité plate d'une spatule.
    • Progressez le long du bord droit de la vitre avant jusqu'à ce qu'il soit séparé de l'écran.
    • Il peut être utile d'insérer un médiator de guitare ou un autre objet fin en plastique pour empêcher le coin supérieur droit de la vitre avant de se recoller sur l'ensemble écran.
    If you don't have a guitar pick, playing cards works too.
    Rob - Réponse
    I used old credit cards
  25. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 25, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 25, image 2 de 2
    • Avec votre pistolet à air chaud, ramollissez la colle sous la bordure noire le long du bord supérieur de la vitre.
    • Fixez une ventouse à levier sur le bord supérieur de la vitre avant et tirez-la pour séparer la vitre de l'écran.
    • Progressez le long du bord supérieur de la vitre, en enlevant précautionneusement la colle avec l'extrémité plate d'une spatule si nécessaire.
  26. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 26, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 26, image 2 de 2
    • Avec le pistolet à air chaud, ramollissez la colle sous la bordure noire du côté du coin supérieur gauche de la vitre.
    • Fixez une ventouse à levier dans le coin supérieur gauche de la vitre avant.
    • Tirez sur la ventouse pendant que vous séparez précautionneusement la vitre de l'ensemble écran avec l'extrémité plate d'une spatule.
    • Après avoir séparé le coin supérieur gauche de l'écran, il peut être utile d'insérer un médiator de guitare ou un autre objet fin en plastique pour empêcher la vitre de se recoller sur l'ensemble écran.
  27. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 27, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 27, image 2 de 2
  28. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 28, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 28, image 2 de 2
    • Maintenant que les bords supérieur, gauche et droit de la vitre sont séparés de l'écran, soulevez doucement le bord supérieur de la vitre et faites-le délicatement pivoter pour l'éloigner de l'écran.
    • Si nécessaire, séparez le bord inférieur de la vitre de l'ensemble écran avec l'extrémité plate d'une spatule.
    • Avant le remontage, veillez à nettoyer l'intérieur de la vitre ainsi que l'écran LCD, car toute poussière ou empreinte digitale à l'intérieur se verra et gênera dès que l'ordinateur sera allumé.
    If you will be reusing the glass, with new adhesive, then you will want to remove the old adhesive. This is a bit of a pain, as alcohol doesn't work, and you need to be careful to avoid damaging the black screen border, which is black paint on the back (adhesive) side of the glass.
    To remove the adhesive, note that it is actually a thin film with rubber cement on both sides. First, use a razor to carefully pull up one corner of the film and gently peel it off of the glass. If you are gentle and slow, the underlying adhesive may also come off; if not, then rubbing with your finger or a hard rubber eraser will do the trick.
    griscom - Réponse
    what to do when new glass starts to peel after a week ?
    labig - Réponse
    If this is a rubber cement based glue, then would rubber solvent / thinner like N-Heptane help the removal process without damaging the black paint ?
    Sandman619 - Réponse
    Don’t remove glue. Just reuse it by heating and sticking it again.
  29. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 29, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 29, image 2 de 2
    • Insérez la pointe d'un outil en plastique entre la vitre de l'écran et la fixation de la caméra et progressez autour de la fixation pour la séparer de la vitre.
    • N'oubliez pas de monter la fixation de la caméra sur la nouvelle vitre avant lors du remontage.
    This step is only needed if replacing the glass. If you are only replacing the LCD, there is no need to do this step
    Rob - Réponse
  30. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 30, image 1 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 30, image 2 de 3 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 30, image 3 de 3
    • Il est possible que la nappe de la caméra se prenne dans la colle sur la vitre, puis se déconnecte de la carte caméra au moment où vous soulevez la vitre. Si la nappe est toujours connectée à la carte caméra, sautez cette étape.
    • Pour reconnecter la nappe de la caméra, enlevez d'abord le morceau de mousse autocollante sur la prise ZIF de la nappe avec la pointe d'une spatule.
    • Toujours avec la pointe de la spatule, ouvrez le clapet de retenue ZIF de la prise de la nappe de la caméra.
    • Insérez la nappe de la caméra dans sa prise sur la carte caméra et refermez le clapet de retenue ZIF avec la pointe de la spatule pour maintenir la nappe en place.
    • Refixez le morceau de mousse autocollante couvrant la prise de la nappe de la caméra.
  31. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Écran LCD: étape 31, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010, Écran LCD: étape 31, image 2 de 2
    • Faites glisser le cache charnière vers la droite de l'écran.
    • Le cache charnière se déplacera d'environ 0,6 cm. N'essayez pas de forcer pour aller plus à droite.
    • Au moment de remonter le cache charnière, veillez à y glisser les composants qui dépassent du bord inférieur de l'écran, en les décalant d'environ 0,6 cm vers la droite par rapport à la position finale de l'écran.
    Do you necessarily need to remove the glass before you can remove the clutch cover?
    aye oh - Réponse
  32. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 32, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 32, image 2 de 2
    • En commençant tout à droite, faites jouer le cache charnière tout le long de son axe pendant que vous l'ôtez de la charnière.
    • En progressant de droite à gauche, soulevez et dégagez soigneusement le cache charnière du bord inférieur de l'ensemble écran.
    • Ôtez le cache charnière du cache inférieur et mettez-le de côté.
    • Au moment de réinstaller le cache charnière, veillez à élargir l'ouverture quand vous faites glisser dessus le petit cache en plastique noir esthétique, qui recouvre l'extrémité libre du cache charnière quand celui-ci est en place. Le cache esthétique est maintenu à la charnière droite par des attaches en plastique très fines et fragiles.
  33. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 33, image 1 de 1
    • Dévissez les six vis cruciformes de 2,9 mm fixant le panneau LCD au cache avant.
    Hey guys, I need to get the part where the screws are on, whats its name or where could I find it? That part on my Computer broke.... Do you guys think its possible to guet it somewhere?
    diegoantegr31 - Réponse
  34. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 34, image 1 de 1
    • Tirez l'écran LCD vers le bord supérieur de l'écran pour faire glisser le système de circuits hors de son emplacement le long du bord inférieur de l'écran en aluminium.
    • Il peut être utile de faire passer d'une main le câble de données de l'écran à travers son canal dans le support en aluminium de l'écran pendant que de l'autre, vous tirez l'écran LCD vers le bord supérieur de l'écran.
  35. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 35, image 1 de 1
    • Décollez le morceau d'adhésif recouvrant le connecteur du câble de données de l'écran sur le bord le plus proche de l'écran LCD.
  36. Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 36, image 1 de 2 Remplacement de l'écran LCD du MacBook Pro 15" Unibody mi-2010: étape 36, image 2 de 2
    • Avec la pointe d'une spatule (spudger), ouvrez le fin clapet de retenue en acier fixant le câble de données de l'écran à sa prise sur l'écran LCD.
    • Tirez le câble de données de l'écran tout droit hors de sa prise sur l'écran.
    • Ôtez l'écran LCD de l'ensemble écran et mettez-le de côté.
    • Si vous remplacez le câble LVDS/de données de l'écran, retirez-le tout simplement de sa fente dans la coque de l'écran.
    Danke für das Bereitstellen der Anleitung dadurch konnte ich mein MacBook nach 12 Jahren Einsatz, für die nächsten Jahre fit machen.
    Thanks you for providing this Manuel. It helped me, after 12 year of use to make my MacBook fit for the coming years.
    Albert Zweistein - Réponse
Pour remonter votre ordinateur, suivez ces instructions en sens inverse.
39 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
8 commentaires
Everything in this guide is simple, except for tearing the glass plate off. I tried with a hairdryer (1200 Watt) first, without success. Then I used a hot air gun (at 400 deg. Celcius, about 750 Fahrenheit). It worked like a charm, but my rubber edge is somewhat shiny, and in one area there's a fingerprint now. Nevertheless, this operation saved me 400 Euros and I'm happy I did it.
arnebakker - Réponse
I followed the guide and it worked very well. However, after heating the glass for removal I found the lower right corner to be the easiest. Then I used an old credit card to separate the glass from the frame by sliding it around. The hardest part was installing the new LCD panel and glass because of dirt particles and fingerprints. Great tutorial and guide.
RodriguezAlberto - Réponse
For each step in the disassembly process, put the different screws into different shotglasses. Don't leave the screws lying around your desk unless you are a pro.
On a piece of paper, write the step #, and place the shotglass on it. If you have cats who might knock over your shotglasses, label them (the shotglasses, not the cats) using a piece of scotch tape. Then put them where they will not get destroyed by mischievous felines like a roll of toilet paper when you forget to close the bathroom door.
Read all comments in this section; they helped me a lot. DISCLAIMER: I am an idiot, and I confused the shotglasses containing cable restraints. I then spent about an hour trying to figure out where I'd gone wrong before I realized that the restraint in the photo was not the one in my hand. No wonder my father always gives me that look of disappointment when he sees me. Good luck!
Robert Burt - Réponse
Thank you ifixit for making this sound easy. I just shattered my display.
fatlard1993 - Réponse
Think you from algeria
fouad hamdouche - Réponse
where is the backlight inverter?
firminle - Réponse
Hi, are these instructions the same for the 'Glossy option'?
Thanks
K J - Réponse
One more thing, replacing the screen when the translucent 'Apple' icon on the top case seems to have failed adhesive or bond and the old failing screen seems to be failed around this Apple area with a bright smudgy corona presently noticeable at centre screen. Can the white plastic of the Apple be 're-sealed' at the same time as any LED panel replacement?
Thanks again
K J - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 116
Total : 104,772
