Aller au contenu principal
Remplacement de la façade de la Nintendo Wii
Ce dont vous avez besoin
  1. Remplacement de la façade de la Nintendo Wii, Façade: étape 1, image 1 de 2 Remplacement de la façade de la Nintendo Wii, Façade: étape 1, image 2 de 2
    • Utilisez une spatule (spudger) en métal pour retirer les caches de vis en plastique blanc, collés sous la coque inférieure, à l'avant de la Wii.
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - Réponse
    Don’t mistakenly remove the rubber case feet
    Bob Trout - Réponse
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - Réponse
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - Réponse
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - Réponse
    Very helpful suggestion, thanks!
    Christopher Reese -
    Caution: Before you begin disassembly. If possible, power on your Wii, and attempt to eject whatever disk you may have in the drive.
    Steve - Réponse
    1:
    I'd recommend removing the RTC Battery before starting to completely remove all power. You can see how in step 15.
    2:
    When removing the screw covers I'd recommend inserting tweezers in the bottom corners facing away from the rubber feet.
    When the tweezers are inserted you should push them down to grab on to the cover and pull it off.
    Macro Man - Réponse
  2. Remplacement de la façade de la Nintendo Wii: étape 2, image 1 de 1
    • Enlevez les deux vis Tri-Point de 8,3 mm dont vous venez d'enlever les caches.
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - Réponse
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - Réponse
    I have an ifixit kit and the Y1 didn't fit. I ended up using a Y0 and it worked.
    Macro Man -
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - Réponse
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - Réponse
    How do you make one ? If you don’t have the screwdriver
    Ethan - Réponse
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - Réponse
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - Réponse
    My two screws hidden are on the backend of the Wii. This picture shows them on the front.
    Leah Wendleton - Réponse
    I had to hold the tri point driver in a vice-grip to get the leverage to get these screws out
    Bob Schwarz - Réponse
    These screws were really tough for me too. Amazon screw driver was stripping them. I attached a 7 mm socket to the end of the screwdriver and got enough force to get them out.
    NateB - Réponse
  3. Remplacement de la façade de la Nintendo Wii: étape 3, image 1 de 1
    • Enlevez la vis cruciforme de 5,9 mm située sous la trappe d'accès aux ports contrôleur, la plus proche de la façade.
    Pry the square rubber piece in the middle, not the hard plastic square frame.
    David Will - Réponse
  4. Remplacement de la façade de la Nintendo Wii: étape 4, image 1 de 1
    • Utilisez une spatule en métal pour retirer le patin en caoutchouc collé sur le côté de la Wii, près de l'ouverture du lecteur DVD.
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - Réponse
  5. Remplacement de la façade de la Nintendo Wii: étape 5, image 1 de 1
    • Enlevez la vis cruciforme de 5,9 mm cachée sous le patin que vous venez d'enlever.
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - Réponse
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - Réponse
  6. Remplacement de la façade de la Nintendo Wii: étape 6, image 1 de 2 Remplacement de la façade de la Nintendo Wii: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Tirez délicatement la façade de l'avant de la Wii.
    • Utilisez une pincette pour déconnecter le connecteur en plastique du câble LED de la carte mère.
    • Retirez la façade.
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - Réponse
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - Réponse
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - Réponse
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - Réponse
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - Réponse
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - Réponse
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - Réponse
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - Réponse
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - Réponse
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - Réponse
    Needlenose pliers did the trick for us!
    Ron Cormier - Réponse
    Needlenose pliers did it for us!
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - Réponse
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - Réponse
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - Réponse
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - Réponse
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - Réponse
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - Réponse
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - Réponse
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - Réponse
Pour remonter l'appareil, suivez les instructions dans l'ordre inverse.
24 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 Guide Comments
Any more to do if pressing the on button does nothing, its still red power light?
Kyrre - Réponse
Tanks for this guide Btw
Kyrre - Réponse
Thanks for the guide, I just wish it continued with replacing the components within the faceplate, as I wanted to replace the white shell. Still helpful though!
Cynthia - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 69
30 derniers jours : 371
Total : 57,122
