Aller au contenu principal
Remplacement des boutons JBL Charge 3
Ce dont vous avez besoin
  1. Remplacement des boutons JBL Charge 3, Coque avant: étape 1, image 1 de 3 Remplacement des boutons JBL Charge 3, Coque avant: étape 1, image 2 de 3 Remplacement des boutons JBL Charge 3, Coque avant: étape 1, image 3 de 3
    • Retournez votre enceinte et insérez l'outil d'ouverture en plastique à la verticale dans le fente de la coque avant.
    • Tirez doucement l'outil vers l'extérieur pour retirer les quatre clips qui maintiennent la coque en place.
    • Répétez cette manipulation pour chacun des quatre coins de la coque avant.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Réponse
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - Réponse
    There are two Phillips head screws to remove before prying the cover off
    jason - Réponse
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - Réponse
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - Réponse
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - Réponse
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - Réponse
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - Réponse
  2. Remplacement des boutons JBL Charge 3: étape 2, image 1 de 1
    • Extrayez délicatement la coque des deux côtés et enlevez-la du châssis de l'enceinte.
    • L'intérieur de la coque avant comprend des des trous qui doivent correspondre au châssis de l'enceinte pour un remontage correct.
    • Retirer la coque avant n'affecte pas l'étanchéité de l'appareil. En revanche, retirer tout autre élément de votre enceinte nécessitera d'enlever les scellés et les joints d'étanchéité. Votre appareil pourrait ne plus être étanche après leur manipulation.
    Include dissembling the plastic cover? cover?
    KanGoon - Réponse
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Very good guide! Pics and descriptions make this easy!
    John G Petko - Réponse
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - Réponse
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - Réponse
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - Réponse
    Me too. Saw the screws after I'd popped it off.
    Del Taylor -
    It doesn't look fixable. Can't get the cover to stay on anymore. Ideas?
    Del Taylor - Réponse
  3. Remplacement des boutons JBL Charge 3, Boutons: étape 3, image 1 de 2 Remplacement des boutons JBL Charge 3, Boutons: étape 3, image 2 de 2
    • Utilisez votre outil d'ouvertur en plastique pour faire levier autour des bords du cache des boutons. Ceci va commencer à séparer l'adhésif du cache.
    • Enlever la cache des boutons avec votre main dès que vous avez assez séparé de votre enceinte pour l'attraper.
  4. Remplacement des boutons JBL Charge 3: étape 4, image 1 de 2 Remplacement des boutons JBL Charge 3: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Levez le clapet de vérouillage du connecteur ZIF.
    • Tirez délicatement sur le câble ZIF avec une pincette.
    What is the purpose of pulling out the ZIF connector cable with tweezers? What do you do after you you've pulled it out?
    Bradford J Stallworth - Réponse
Pour réassembler votre appareil, suivez ces étapes dans le sens inverse.
15 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Sunmin Yoon
Membre depuis le 10/30/18
1 970 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G1, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 membres
26 tutoriels rédigés
4 commentaires
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - Réponse
Where do i buy new buttons?
Thomas Bjerregaard - Réponse
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - Réponse
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 51
30 derniers jours : 227
Total : 25,538
