Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Repair electronics
      • Seen from below, the handpiece is oval-shaped. Wrap with a cloth, with a pair of pliers, a nutcracker or similar. start where the feet are and put the oval in a circle. At the same time, press the handpiece upside down, ie with the metal shank in front, onto a wooden base, whereby the inner life is expelled.
      Demander à FixBot
      Ajouter un commentaire
    1. Repair electronics, Remove handpiece base: étape 2, image 1 de 1
      • Remove the underside of the handpiece by carefully lifting the tabs at the two farthest vertexes of the oval with a small screwdriver.
      Demander à FixBot
    2. Repair electronics, Remove the rubber pad from the motherboard: étape 3, image 1 de 1
      • Remove the rubber pad from the motherboard
      Demander à FixBot
    3. Repair electronics, Remove plastic cap from metal shaft: étape 4, image 1 de 1
      • Use a puller to remove the plastic cap from the metal shaft to expose the defective rubber boot.
      Demander à FixBot
      • Thoroughly clean all housing parts with water and cloth.
      • Thoroughly clean the electronics and mechanics with isopropyl alcohol and a fine brush.
      • Also completely rid the metal shaft of any residue.
      Demander à FixBot
    4. Repair electronics, Repair electronics: étape 6, image 1 de 1
      • Place the inner workings of the handpiece without housing parts in a container in such a way that the main board points downwards and the battery points upwards.
      • Now fill the container with isopropyl alcohol just enough so that the liquid level reaches the circuit board.
      • Leave to stand for 1-2 hours under supervision, then remove the device from the liquid bath and allow to dry.
      Demander à FixBot
    5. Repair electronics, Replace rubber sleeve: étape 7, image 1 de 1
      • The defective rubber sleeve on the metal shaft must be replaced. A spare part is available for less than € 4 on eBay under the following designation: "Philips electric toothbrush Waterproof sealing parts for HX6730 HX6930 HX9340».
      Demander à FixBot
Repeat the steps in order to reassemble your device.
Merci à ces traducteurs :
de en
94%
irlanda nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Gerd Conzetti
Membre depuis le 11/12/17
319 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 50
Total : 1,816
