Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repairing Nintendo 64 Audio Video Port
Ce dont vous avez besoin
  1. Repairing Nintendo 64 Audio Video Port, Repairing Nintendo 64 Audio Video Port: étape 1, image 1 de 1
    • Open the Nintendo 64 in order to operate on the motherboard. Steps to open it can be found here.
    Demander à FixBot
    Ajouter un commentaire
  2. Repairing Nintendo 64 Audio Video Port: étape 2, image 1 de 1
    • Locate the audio/video connections at the rear right area of the motherboard. There should be six bent strips of gold metal connecting to the motherboard. For unrestricted access to the A/V area, remove the plastic plate above it by unscrewing the left and right screws. After unscrewing, lift the motherboard a bit in order to pull the plate off.
    Demander à FixBot
  3. Repairing Nintendo 64 Audio Video Port: étape 3, image 1 de 2 Repairing Nintendo 64 Audio Video Port: étape 3, image 2 de 2
    • Heat up the small contact (between each strip and the motherboard) with a soldering iron. For best results, heat all 6 contact points so that they become soft and moldable, and then allow them to dry and reform a solid connection.
    Demander à FixBot
    • Heating it and letting it reform will potentially fix any oxidation which could prevent the flow of electricity, so let the contact reform and dry, and then reattach the plate onto the 6-prong area. Test the output for correct video signal and/or audio signal (depending on which problem was occurring).
    Demander à FixBot
10 autres ont terminé cette réparation.
Benjamin Donnelly
Membre depuis le 10/29/13
1 282 Réputation
4 tutoriels rédigés
Équipe
University of Maryland, Team 1-6, Shastany Fall 2013 Membre de l'équipe University of Maryland, Team 1-6, Shastany Fall 2013
UMD-SHASTANY-F13S1G6
3 membres
8 tutoriels rédigés
4 commentaires de tutoriel
Un grand merci, grâce à vous ma N64 re-fonctionne !
Edocle - Réponse Partager
Excellent guide! Repaired my brothers N64 in one shot. Make sure you have lots of screw holders there's like 8 different types of screws.
C Parker - Réponse Partager
Wow- it worked thank you!!!
De Lixer - Réponse Partager
Any recommendations for corrosion of the gold metal strips? I have cleaned them off as much as possible but some of them are badly damaged. Can they be repaired or replaced?
J Miller - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 55
30 derniers jours : 187
Total : 31,341
