Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ring Video Doorbell Camera Replacement
Ce dont vous avez besoin
  1. Ring Video Doorbell  Camera Replacement, Camera: étape 1, image 1 de 3 Ring Video Doorbell  Camera Replacement, Camera: étape 1, image 2 de 3 Ring Video Doorbell  Camera Replacement, Camera: étape 1, image 3 de 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminum plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. Ring Video Doorbell  Camera Replacement: étape 2, image 1 de 3 Ring Video Doorbell  Camera Replacement: étape 2, image 2 de 3 Ring Video Doorbell  Camera Replacement: étape 2, image 3 de 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
    Demander à FixBot
  3. Ring Video Doorbell  Camera Replacement: étape 3, image 1 de 3 Ring Video Doorbell  Camera Replacement: étape 3, image 2 de 3 Ring Video Doorbell  Camera Replacement: étape 3, image 3 de 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
    Demander à FixBot
  4. Ring Video Doorbell  Camera Replacement: étape 4, image 1 de 2 Ring Video Doorbell  Camera Replacement: étape 4, image 2 de 2
    • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
    • Replace camera, and follow the steps in reverse order to reassemble
    Demander à FixBot
  5. Ring Video Doorbell  Camera Replacement: étape 5, image 1 de 2 Ring Video Doorbell  Camera Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
    • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
    Demander à FixBot
3 autres ont terminé cette réparation.
Isaiah Wilson
Membre depuis le 02/20/18
231 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 membres
15 tutoriels rédigés
11 commentaires de tutoriel
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - Réponse Partager
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - Réponse Partager
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend - Réponse Partager
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - Réponse Partager
Has anyone found a replacement camera online?
christina.stewart - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 52
30 derniers jours : 185
Total : 20,597
