Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Note10+ 5G Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the SIM card: étape 1, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the SIM card: étape 1, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the SIM card: étape 1, image 3 de 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Note10+ 5G Motherboard Replacement, Heat the rear cover: étape 2, image 1 de 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Demander à FixBot
  3. Samsung Galaxy Note10+ 5G Motherboard Replacement, Insert an opening pick: étape 3, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Insert an opening pick: étape 3, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Demander à FixBot
  4. Samsung Galaxy Note10+ 5G Motherboard Replacement, Begin to slice the adhesive: étape 4, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Begin to slice the adhesive: étape 4, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Begin to slice the adhesive: étape 4, image 3 de 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    Demander à FixBot
  5. Samsung Galaxy Note10+ 5G Motherboard Replacement, Slice around the perimeter of the phone: étape 5, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Slice around the perimeter of the phone: étape 5, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Slice around the perimeter of the phone: étape 5, image 3 de 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
    Demander à FixBot
  6. Samsung Galaxy Note10+ 5G Motherboard Replacement, Lift off the rear cover: étape 6, image 1 de 2 Samsung Galaxy Note10+ 5G Motherboard Replacement, Lift off the rear cover: étape 6, image 2 de 2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
    Demander à FixBot
  7. Samsung Galaxy Note10+ 5G Motherboard Replacement, Lift up the metal cover: étape 7, image 1 de 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
    Demander à FixBot
  8. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 8, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 8, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
    Demander à FixBot
  9. Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the battery: étape 9, image 1 de 2 Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the battery: étape 9, image 2 de 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
    Demander à FixBot
  10. Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the wireless charging coil: étape 10, image 1 de 2 Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the wireless charging coil: étape 10, image 2 de 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    Demander à FixBot
  11. Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the wireless charging coil: étape 11, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the wireless charging coil: étape 11, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the wireless charging coil: étape 11, image 3 de 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
    Demander à FixBot
  12. Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the loudspeaker screws: étape 12, image 1 de 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
    Demander à FixBot
  13. Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the loudspeaker: étape 13, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the loudspeaker: étape 13, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the loudspeaker: étape 13, image 3 de 3
    • Use a pair of tweezers to remove the loudspeaker.
    Demander à FixBot
  14. Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the interconnect cables: étape 14, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the interconnect cables: étape 14, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the interconnect cables: étape 14, image 3 de 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
    Demander à FixBot
  15. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 15, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 15, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 15, image 3 de 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
    Demander à FixBot
  16. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 16, image 1 de 1
    • Remove the main interconnect cable.
    Demander à FixBot
  17. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 17, image 1 de 2 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 17, image 2 de 2
    • Don't try to remove the secondary interconnect cable. The cable is connected to the side 5G mmWave antenna.
    • Use a spudger or your fingers to gently fold the secondary interconnect cable away from the battery.
    Demander à FixBot
  18. Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the top plastic cover: étape 18, image 1 de 1
    • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
    Demander à FixBot
  19. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 19, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 19, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 19, image 3 de 3
    • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
    Demander à FixBot
  20. Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the motherboard connectors: étape 20, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the motherboard connectors: étape 20, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Disconnect the motherboard connectors: étape 20, image 3 de 3
    • Use the pointed end of a spudger to disconnect the touch layer connector from the motherboard.
    • Disconnect the side button connector from the motherboard.
    Demander à FixBot
  21. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 21, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 21, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 21, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the 5G mmWave antenna connector from the motherboard.
    • Gently bend the cable away from the motherboard.
    Demander à FixBot
  22. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 22, image 1 de 2 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 22, image 2 de 2
    • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
    Demander à FixBot
  23. Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 23, image 1 de 2 Samsung Galaxy Note10+ 5G Motherboard Replacement: étape 23, image 2 de 2
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
    Demander à FixBot
  24. Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the motherboard: étape 24, image 1 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the motherboard: étape 24, image 2 de 3 Samsung Galaxy Note10+ 5G Motherboard Replacement, Remove the motherboard: étape 24, image 3 de 3
    • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
    • Remove the motherboard.
    • If the motherboard feels stuck, make sure that you ejected the SIM tray.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Arthur Shi
Membre depuis le 01/03/18
343 709 Réputation
915 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
28 236 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 41
Total : 2,227
