Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ce dont vous avez besoin
Vidéo d'introduction
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung Galaxy Note7, utilisez notre manuel de réparation.
  1. Samsung Galaxy Note7 Teardown, Samsung Galaxy Note7 Teardown: étape 1, image 1 de 3 Samsung Galaxy Note7 Teardown, Samsung Galaxy Note7 Teardown: étape 1, image 2 de 3 Samsung Galaxy Note7 Teardown, Samsung Galaxy Note7 Teardown: étape 1, image 3 de 3
    • It's a mix of new and familiar as we peruse the Note7's specs:
    • Curved panel 5.7" Super AMOLED display with 2560 × 1440 resolution (518 ppi) and Gorilla Glass 5
    • Qualcomm Snapdragon 820 processor with 4 GB RAM + Adreno 530 GPU
    • 12-megapixel, ƒ/1.7 rear camera with OIS, dual pixel autofocus, 4K video; 5-megapixel/1080p selfie camera
    • 64 GB internal storage, with an additional 256 GB available via MicroSD expansion
    • Iris scanner, fingerprint scanner
    • S Pen stylus, USB-C, and headphone jack (phew)
    • IP68 dust and water resistance rating
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Note7 Teardown: étape 2, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 2, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 2, image 3 de 3
    • As we boldly go where no tinkerer has gone before, we come across some starports hiding out near the bottom edge. From left to right we observe:
    • Headphone jack
    • USB-C port
    • Microphone port
    • Speaker grille
    • That last one's not a port at all, it's the illustrious S Pen. Removing the S Pen is as smooth as slicing warm butter.
    • Building off the Note5's mid-production design modification, the S Pen doesn't fit into its slot backwards. Now that's progress.
    Demander à FixBot
  3. Samsung Galaxy Note7 Teardown: étape 3, image 1 de 2 Samsung Galaxy Note7 Teardown: étape 3, image 2 de 2
    • Our teardown hands are itching to get down to business, but we take a moment to test out the S Pen.
    • First impressions: this stylus stacks up pretty well against Microsoft's Surface Pen and Apple's Pencil.
    • The S Pen is smaller (and more stow-able) than either, but still has a scan rate of 360 Hz and senses 4,096 levels of pressure compared to the Pencil's 240 Hz and the Surface Pen's 1,024 levels of sensitivity.
    • In an additional level of customization, the S Pen comes with two interchangeable tips: a soft tip for writing on smooth glass, and a hard tip for use with screen protectors.
    Demander à FixBot
  4. Samsung Galaxy Note7 Teardown: étape 4, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 4, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 4, image 3 de 3
    • If opening stubbornly adhered Samsung devices was an Olympic sport, our teardown room would be filled with gold medals.
    • We take a minute to stretch while the iOpener works its magic, softening the adhesive under the rear glass.
    • Bang! The gun sounds. We fly off the starting blocks, iSclack and opening pick in hand. Pop! The rear glass dislodges from the chassis. Whoosh! The rest of the adhesive didn't stand a chance. Ka-pow! We're in.
    • And the crowd goes wild. Okay, but really. This is something of a delicate procedure, and we still miss the days of plastic peel off rear cases.
    Demander à FixBot
  5. Samsung Galaxy Note7 Teardown: étape 5, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 5, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 5, image 3 de 3
    • Tinkerers love Phillips screws. Seeing these good ol' familiar screws draws our focus down to what they're securing: a sweet wireless charging coil.
    • Samsung states that "once you've had wireless charging, there's no going back." It's like having the event horizon of a black hole right in your phone, with all the convenience that entails.
    • We suspect the NFC antenna is also bundled into this wafer-thin assembly. NFC is no stranger to Galaxy Phones.
    • With that, we get our first full reveal of the Note7. [Cue oohs and aahs]
    Demander à FixBot
  6. Samsung Galaxy Note7 Teardown: étape 6, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 6, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 6, image 3 de 3
    • We come across an unusual battery cable design. At first glance, this is most definitely a slide. We're getting a little motion sick just looking at all of those winding curves.
    • Fortunately for us, a flick of a spudger is all it takes to pry the (off-kilter) battery connector cable off the motherboard.
    • With battery disconnected we delve deeper.
    • First victim: the single speaker, with built in antenna.
    • Of note, the speaker pass-through has a gasket and mesh liner, in addition to the grille punched into the case (likely a waterproofing measure).
    Demander à FixBot
  7. Samsung Galaxy Note7 Teardown: étape 7, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 7, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 7, image 3 de 3
    • We could almost hear the battery laugh in our faces when we tried to pluck it out bare-handed—but our inner Hulk emerges as we muscle with all the might our spudger can muster.
    • This 3500 mAh, 13.48 Wh battery is significantly more powerful than the 10.45 Wh one found in the similarly sized iPhone 6s Plus, but it falls just a bit short of its smaller sibling, the Galaxy S7 Edge, which comes in at 13.86 Wh.
    • Curiously, the Note7's battery is fortified by walls carved from the rear case, providing extra structural integrity, and maybe even some water protection.
    Demander à FixBot
  8. Samsung Galaxy Note7 Teardown: étape 8, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 8, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 8, image 3 de 3
    • Out comes the motherboard, with three little cameras in tow.
    • Front and rear cameras are familiar fare on smartphones, so what's the third camera for?
    • That would be the Note7's trick iris scanner. It's actually a two-part system: a nearby infrared blaster invisibly lights up your eye, while the sensor captures an image that's said to be more secure than a fingerprint.
    • For comparison we have the iris scanner (right) with the Note7's 5-megapixel, ƒ/1.7 selfie cam (left).
    • And for the X-ray comparison, here we have the two cameras still in the device.
    Demander à FixBot
  9. Samsung Galaxy Note7 Teardown: étape 9, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 9, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    • With the motherboard deftly extracted, we take our tweezers to the hefty main camera and line him up for closer look.
    • It's déjà vu all over again as we pull out what appears to be the same Sony IMX260-based main camera that we uncovered in the S7 and S7 Edge.
    • ... And the similarities go further, all the way down to:
    • the Winbond Q32FWXGIG serial flash memory
    • STMicroelectronics L2G2IS 2-Axis MEMS OIS Gyroscope
    • Renesas OIS Driver
    Demander à FixBot
  10. Samsung Galaxy Note7 Teardown: étape 10, image 1 de 1
    • We're down to the meat and potatoes of this teardown, and it seems like Samsung unified more than their product numbering—this chipset is nearly identical to that found in the S7 and S7 Edge.
    • Samsung K3RG2G20CMMGCJ 4 GB LPDDR4 SDRAM layered over a Qualcomm Snapdragon 820
    • Samsung KLUCG4J1CB-B0B1 64 GB Universal Flash Storage 2.0
    • Avago AFEM-9040 multiband multimode module
    • NXP PN67T NFC controller
    • Qorvo QM78064 high band RF fusion module, TQF6260 front-end module and QM63001A diversity receive module
    • Qualcomm WCD9335 audio codec and DSP Group DBMD4 audio/voice processor
    • Murata FAJ15 front-end module
    Demander à FixBot
  11. Samsung Galaxy Note7 Teardown: étape 11, image 1 de 1
    • More note-worthy chips hide on the backside:
    • Samsung 3420S7 G707A3 Wi-Fi module (most likely contains a Broadcom BCM4359 Wi-Fi SoC)
    • Wacom W9018 touch control IC
    • ZF10 110630 0625 (likely NXP Semiconductor I/O expander)
    • Qualcomm PM8996 and PM8004 PMICs
    • Qualcomm QFE3100 envelope tracker
    • Qualcomm WTR4905 and WTR3925 RF transceivers
    • IDT P9221S wireless power receiver (likely an iteration of IDT P9220) + Samsung S2MPB02 camera power management + Maxim Integrated MAX77838 power management IC
    Demander à FixBot
  12. Samsung Galaxy Note7 Teardown: étape 12, image 1 de 2 Samsung Galaxy Note7 Teardown: étape 12, image 2 de 2
    • IC identification, pt. 2:
    • Infineon (previously Cypress Semiconductor) CY8CMBR3145 capacitive touch button controller
    • Samsung Image Processor (likely)
    • Samsung S2MM005X01 power management
    • Maxim Integrated MAX77854F power management
    • Maxim Integrated MAX98506 audio amplifier
    • Texas Instruments BQ25898S battery charger
    • ON Semiconductor FPF3688 load switch
    Demander à FixBot
  13. Samsung Galaxy Note7 Teardown: étape 13, image 1 de 2 Samsung Galaxy Note7 Teardown: étape 13, image 2 de 2
    • IC identification, pt. 3:
    • RDA Microelectronics RDA6213 FM radio transceiver
    • Antenna switch module (likely)
    • NXP Semiconductor BGU8103 GPS/GLONASS/Galileo/BeiDou low noise amplifier
    • NXP Semiconductor BGS8H2 LTE low noise amplifier
    • NXP Semiconductor BGS8L2 LTE low noise amplifier
    • NXP Semiconductor BGS8M2 LTE low noise amplifier
    • Infineon BGS12SN6 SPDT RF switch
    Demander à FixBot
  14. Samsung Galaxy Note7 Teardown: étape 14, image 1 de 2 Samsung Galaxy Note7 Teardown: étape 14, image 2 de 2
    • IC identification, pt. 4 (sensors):
    • Maxim Integrated MAX86902 heart rate sensor (likely)
    • STMicroelectronics LSM6DS3 3-axis accelerometer/gyroscope
    • Bosch Sensortec BMP280 pressure sensor
    • AKM Semiconductor AK09916 3-axis electronic compass
    • Seiko Instruments S-5712CCDL1-I4T1U hall effect sensor
    Demander à FixBot
  15. Samsung Galaxy Note7 Teardown: étape 15, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 15, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 15, image 3 de 3
    • Heading south, we hit the modular headphone jack—ready to let the music flow while keeping water out, with a nice sealing gasket.
    • This phablet ships with an IP68 water resistant rating, meaning it is dust tight, and can survive under 1 meter (or more) of water.
    • The USB-C port is new to the Note line—and while reversibility is handy, change is hard. Samsung kindly includes a micro-USB-to-C adapter to keep your cables relevant.
    • Out goes the daughterboard array! Unlike the one found in the S7, this board used rigid PCB interconnects. This keeps the spidery cable from being flimsy. No one likes flimsy.
    • IC identification:
    • Qualcomm QFE2550 antenna tuner
    • Seiko Instruments S-5712CCDL1-I4T1U hall sensor
    • Semtech SX9320 proximity sensor (likely)
    Demander à FixBot
  16. Samsung Galaxy Note7 Teardown: étape 16, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 16, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 16, image 3 de 3
    • If you like tiny heat pipes, Note7 has you covered. This looks like the same "liquid cooling" copper heat dispersal apparatus we pulled from the vanilla S7 and S7 Edge.
    • Nearby, a note-able amount of glue secures this plastic cover over the S Pen chamber. It's probably there to help ingress-proof the stylus' slot.
    • We're not normally fans of glue—but this waterproofing effort doesn't seem to hinder repair much.
    • Inside, a simple clip grabs the S Pen notches, and a gray rubber bumper protects the nib.
    Demander à FixBot
  17. Samsung Galaxy Note7 Teardown: étape 17, image 1 de 3 Samsung Galaxy Note7 Teardown: étape 17, image 2 de 3 Samsung Galaxy Note7 Teardown: étape 17, image 3 de 3
    • The volume buttons look pretty complicated, but that doesn't slow us down. Braced with years of experience plucking our unibrows, we dive in, a pair of tweezers in hand.
    • First out are the microswitches, followed by a reinforcement bracket full of rubber gaskets. Not quite the same, but similar to another waterproofing approach we've seen.
    • But...what's this? The button covers are oddly trapped within the outer case. We can't pop them out!
    • Could this mean the case is double-walled? Is this a waterproofing feature? Perhaps a structural feature? Your guess is as good as ours.
    Demander à FixBot
  18. Samsung Galaxy Note7 Teardown: étape 18, image 1 de 2 Samsung Galaxy Note7 Teardown: étape 18, image 2 de 2
    • We're down to slim pickings, and the last component to surrender is this front-facing sensor array containing:
    • Status LED
    • IR blaster to enable iris scanning
    • We saw the iris scanning sensor earlier—this component provides the infrared illumination to really make your eyes pop.
    • Proximity sensor (AMS TMD4904 likely)
    Demander à FixBot
  19. Samsung Galaxy Note7 Teardown: étape 19, image 1 de 1
    • And here's the moment you've been waiting for—the exploded (edit: no pun intended) diagram of the Note7.
    Demander à FixBot
  20. Dernières pensées
    • Many components are modular and can be replaced independently.
    • Improved cable routing means the charging port board can be removed without disassembling the display.
    • The battery can be removed without first ousting the motherboard, but tough adhesive and a glued-on rear panel make replacement very difficult.
    • Front and back glass make for double the crackability, and strong adhesive on the rear glass makes it very difficult to gain entry into the device.
    • Because of the curved screen, replacing the front glass without destroying the display is probably impossible.
    Indice de réparabilité
    4
    Indice de réparabilité de 4 sur 10
    (10 étant le plus facile à réparer)
Scott Havard
Membre depuis le 06/27/16
51 299 Réputation
31 tutoriels rédigés
48 commentaires de tutoriel
would you think its worth upgrading from the s7edge to the Note 7?
Scott Ream - Réponse Partager
I would do that.
Gama Goat - Réponse Partager
I would get the iPhone 7 :)
Gigabit87898 - Réponse Partager
Yeah I would, that stylus is so %#*@ sexy.
okdna - Réponse Partager
For sure, note 7 is a beast of a phone, you wont regret it
Chad Preslar - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 122
Total : 164,651
