Introduction
This guide shows how to remove and replace the dual rear camera module for the Samsung Galaxy S10e.
You’ll need to remove the motherboard in order to disconnect the camera module.
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press firmly to eject the tray.
Turn your phone off completely before you begin this repair.
Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Press the edge of an opening tool into the gap.
Slide the opening tool along the right edge of the phone to slice through the adhesive securing the back cover.
I found that using opening picks for the entire repair was much easier then the pry tool, but that could just be me
Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
Use the flat end of a spudger to pry the battery connector straight up from its socket and disconnect it.
Use a Phillips driver to remove the seven 3.9 mm screws securing the loudspeaker.
Use the flat end of a spudger to pry up and disconnect the screen connector from its motherboard socket.
Use a spudger to pry up and disconnect the front facing camera connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the fingerprint sensor connector from its motherboard socket.
Use a spudger to pry up and disconnect the headphone jack connector from its motherboard socket.
I did not manage to remove the headphone jack plug with the sponger, so I used some headphones instead which was very easy.
Use a Phillips driver to remove the three screws securing the motherboard:
One 3.7 mm screw above the rear-facing camera
Two 3.7 mm screws flanking the USB-C port
Use your fingers to lift the top edge of the motherboard out of the frame.
Gently pull the motherboard towards the top of the frame to release the lightly adhered USB-C port.
Remove the motherboard.
Seat the USB-C port end of the motherboard firmly against the bottom frame edge.
Lay the motherboard into the frame and make sure not to trap any connectors underneath it.
Flip the motherboard over.
Use a spudger to pry up and disconnect the two camera connectors from their motherboard sockets.
Apply a heated iOpener to the camera module for one minute to loosen the adhesive.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
