Aller au contenu principal
Samsung Galaxy S21 Primary Interconnect Cable Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Heat the bottom edge: étape 1, image 1 de 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
  2. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the bottom adhesive: étape 2, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the bottom adhesive: étape 2, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the bottom adhesive: étape 2, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  3. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Slice the bottom adhesive: étape 3, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Slice the bottom adhesive: étape 3, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Slice the bottom adhesive: étape 3, image 3 de 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Heat the left edge: étape 4, image 1 de 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  5. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the left adhesive: étape 5, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the left adhesive: étape 5, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the left adhesive: étape 5, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  6. Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 6, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 6, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 6, image 3 de 3
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  7. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Heat the right edge: étape 7, image 1 de 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the right adhesive: étape 8, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the right adhesive: étape 8, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the right adhesive: étape 8, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  9. Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 9, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 9, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 9, image 3 de 3
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  10. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the corner adhesive: étape 10, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the corner adhesive: étape 10, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the corner adhesive: étape 10, image 3 de 3
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  11. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Reposition the opening picks: étape 11, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Reposition the opening picks: étape 11, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Reposition the opening picks: étape 11, image 3 de 3
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  12. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Heat the camera shell: étape 12, image 1 de 1
    • Heat an iOpener and apply it to the camera shell for two minutes.
  13. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the camera shell adhesive: étape 13, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the camera shell adhesive: étape 13, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the camera shell adhesive: étape 13, image 3 de 3
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  14. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the camera shell adhesive (alternate method): étape 14, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the camera shell adhesive (alternate method): étape 14, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Separate the camera shell adhesive (alternate method): étape 14, image 3 de 3
    • Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
    • Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
    • Be careful with this method, as you risk cracking the plastic back cover.
  15. Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 15, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 15, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 15, image 3 de 3
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 16, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 16, image 2 de 2
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  17. Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 17, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 17, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 17, image 3 de 3
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  18. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the back cover: étape 18, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the back cover: étape 18, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Unfasten the motherboard bracket: étape 19, image 1 de 1
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
    • Throughout this repair, keep track of each screw, and make sure it goes back exactly where it came from.
  20. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Unclip the motherboard bracket: étape 20, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Unclip the motherboard bracket: étape 20, image 2 de 2
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  21. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Disconnect the battery: étape 21, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Disconnect the battery: étape 21, image 2 de 2
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Disconnect the wireless charging coil: étape 22, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Disconnect the wireless charging coil: étape 22, image 2 de 2
    • While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  23. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the wireless charging coil: étape 23, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the wireless charging coil: étape 23, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the wireless charging coil: étape 23, image 3 de 3
    • The wireless charging coil is secured to the phone with light adhesive.
    • Use your fingers to gently peel the wireless charging coil away from the phone.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
  24. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Unfasten the loudspeaker: étape 24, image 1 de 1
    • Use a Phillips screwdriver to remove the six 4 mm screws securing the loudspeaker to the frame.
  25. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the loudspeaker: étape 25, image 1 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the loudspeaker: étape 25, image 2 de 3 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the loudspeaker: étape 25, image 3 de 3
    • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
    • Remove the loudspeaker.
  26. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Disconnect the primary interconnect cable: étape 26, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement, Disconnect the primary interconnect cable: étape 26, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's bottom press connector.
  27. Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 27, image 1 de 2 Samsung Galaxy S21 Primary Interconnect Cable Replacement: étape 27, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's top press connector.
  28. Samsung Galaxy S21 Primary Interconnect Cable Replacement, Remove the primary interconnect cable: étape 28, image 1 de 1
    • Use tweezers, or your fingers, to remove the primary interconnect cable.
After you've completed the repair, follow this guide to test your repair.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
166 857 Réputation
769 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
20 385 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 50
Total : 1,135
