Aller au contenu principal
Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: étape 1, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: étape 1, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: étape 1, image 3 de 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Heat the bottom edge: étape 2, image 1 de 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are all susceptible to heat damage.
  3. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the bottom adhesive: étape 3, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the bottom adhesive: étape 3, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the bottom adhesive: étape 3, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  4. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Slice the bottom adhesive: étape 4, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Slice the bottom adhesive: étape 4, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Slice the bottom adhesive: étape 4, image 3 de 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Heat the left edge: étape 5, image 1 de 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  6. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the left adhesive: étape 6, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the left adhesive: étape 6, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the left adhesive: étape 6, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  7. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 7, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 7, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 7, image 3 de 3
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  8. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Heat the right edge: étape 8, image 1 de 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  9. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the right adhesive: étape 9, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the right adhesive: étape 9, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the right adhesive: étape 9, image 3 de 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  10. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 10, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 10, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 10, image 3 de 3
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  11. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the corner adhesive: étape 11, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the corner adhesive: étape 11, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the corner adhesive: étape 11, image 3 de 3
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  12. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Reposition the opening picks: étape 12, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Reposition the opening picks: étape 12, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Reposition the opening picks: étape 12, image 3 de 3
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  13. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Heat the camera shell: étape 13, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Heat the camera shell: étape 13, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Heat the camera shell: étape 13, image 3 de 3
    • Heat an iOpener and apply it to the camera shell for two minutes.
    • As you wait for the adhesive to loosen, note the following:
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  14. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the camera shell adhesive: étape 14, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the camera shell adhesive: étape 14, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Separate the camera shell adhesive: étape 14, image 3 de 3
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  15. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 15, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 15, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 15, image 3 de 3
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 16, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 16, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement: étape 16, image 3 de 3
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  17. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: étape 17, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: étape 17, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unfasten the motherboard bracket: étape 18, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unfasten the motherboard bracket: étape 18, image 2 de 2
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
  19. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unclip the motherboard bracket: étape 19, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unclip the motherboard bracket: étape 19, image 2 de 2
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  20. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: étape 20, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: étape 20, image 2 de 2
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the wireless charging coil: étape 21, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the wireless charging coil: étape 21, image 2 de 2
    • While holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  22. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: étape 22, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: étape 22, image 2 de 2
    • Use a Phillips screwdriver to remove the six 4 mm-long screws securing the loudspeaker to the frame.
  23. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: étape 23, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: étape 23, image 2 de 2
    • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
  24. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the wireless charging coil: étape 24, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the wireless charging coil: étape 24, image 2 de 2
    • Remove the wireless charging coil.
  25. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the primary interconnect cable: étape 25, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the primary interconnect cable: étape 25, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's press connector.
  26. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the secondary interconnect cable: étape 26, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the secondary interconnect cable: étape 26, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's press connector.
  27. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the secondary/primary interconnect cables: étape 27, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the secondary/primary interconnect cables: étape 27, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Disconnect the secondary/primary interconnect cables: étape 27, image 3 de 3
    • Use a spudger to pry up and disconnect the secondary interconnect cable's press connector.
    • Repeat for the main interconnect cable's press connector.
  28. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the secondary/primary interconnect cables: étape 28, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the secondary/primary interconnect cables: étape 28, image 2 de 2
    • Use tweezers or your fingers to remove both cables.
    • Set the cables aside. You'll reuse them during reassembly.
  29. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unfasten the daughterboard: étape 29, image 1 de 2 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Unfasten the daughterboard: étape 29, image 2 de 2
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the daughterboard to the frame.
  30. Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: étape 30, image 1 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: étape 30, image 2 de 3 Samsung Galaxy S21 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: étape 30, image 3 de 3
    • Use the point of a spudger to pry up the daughterboard.
    • Use your fingers to pull the daughterboard up and away from the bottom of the phone and remove it.
    • If you feel any resistance, the USB-C port could still be caught in its groove. Gently wiggle the daughterboard while pulling until it completely separates from the phone.
20 autres ont terminé cette réparation.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
168 403 Réputation
769 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
119 membres
21 025 tutoriels rédigés
3 commentaires de tutoriel
Ive dome this with 3 boards from amazon and ebay and thay all turn off signal. the usb charging port works on replacements but sim and service do not work. Should a new daughter board work instantly? im having to go back to the broken usb port board and charge via wireless for weeks on end since no boards work correctly.
Jason Murphy - Réponse
I purchased the "Fix Kit" which includes an OEM daughter board from Samsung. This board worked instantly with no issues. SIM cards in these phones might not work with the un-official boards you're getting from Amazon, or there is another issue causing them not to work for your phone.
You can get away with purchasing the part-only option instead of the whole kit. The only tool included that might be hard to source is the suction cup. Otherwise, you can use a hair dryer, thin plastic pieces (guitar picks are cheap) and a small screw driver to do this repair. Sounds like you would already have all the tools needed.
Greg Phillips -
Is this compatible with the S21FE ? or just the S21. Can not seem to find a replacement part for the S21FE specifically.
jsherida0124 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 23
7 derniers jours : 172
30 derniers jours : 740
Total : 26,437
