Aller au contenu principal
Samsung Galaxy S24 Plus Earpiece Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Heat the right edge: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Insert an opening pick: étape 3, image 1 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Insert an opening pick: étape 3, image 2 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the right adhesive: étape 4, image 1 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the right adhesive: étape 4, image 2 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the right adhesive: étape 4, image 3 de 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Heat the bottom edge: étape 5, image 1 de 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the corner adhesive: étape 6, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the corner adhesive: étape 6, image 2 de 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the bottom adhesive: étape 7, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the bottom adhesive: étape 7, image 2 de 2
    • Insert a second pick at the bottom right corner.
    • Slide the opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Heat the left edge: étape 8, image 1 de 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the corner adhesive: étape 9, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the corner adhesive: étape 9, image 2 de 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the left adhesive: étape 10, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the left adhesive: étape 10, image 2 de 2
    • Insert a third opening pick at the bottom left corner.
    • Slide the pick toward the top left corner to separate the adhesive.
    • Leave the pick near the top left corner to prevent the adhesive from resealing.
  11. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Heat the top edge: étape 11, image 1 de 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the corner adhesive: étape 12, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the corner adhesive: étape 12, image 2 de 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
  13. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the top adhesive: étape 13, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the top adhesive: étape 13, image 2 de 2
    • Insert a fourth opening pick at the top left corner.
    • Slide the pick toward the top right corner to separate the adhesive.
    • Leave the pick near the top right corner to prevent the adhesive from resealing.
  14. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the rear mic adhesive: étape 14, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Separate the rear mic adhesive: étape 14, image 2 de 2
    • There's a square of adhesive around the rear microphone, just above the flash.
    • Line up the tip of an opening pick with the flash.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
  15. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the back cover: étape 15, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the back cover: étape 15, image 2 de 2
    • Grab and remove the back cover.
    • If the back cover is not lifting easily, use an opening pick to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive, but your device will lose its IP (Ingress Protection) rating.
    • Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
  16. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Disconnect the wireless charging coil: étape 16, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Disconnect the wireless charging coil: étape 16, image 2 de 2
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the wireless charging coil and loudspeaker screws: étape 17, image 1 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the wireless charging coil and loudspeaker screws: étape 17, image 2 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the wireless charging coil and loudspeaker screws: étape 17, image 3 de 3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  18. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the wireless charging coil and loudspeaker: étape 18, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the wireless charging coil and loudspeaker: étape 18, image 2 de 2
    • Insert the point of a spudger in the notch at the top left corner of the loudspeaker, which is marked by an arrow.
    • Pry up to unclip the loudspeaker from the frame.
  19. Samsung Galaxy S24 Plus Earpiece Speaker Replacement: étape 19, image 1 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement: étape 19, image 2 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement: étape 19, image 3 de 3
    • Use your fingers to lift the loudspeaker away from the frame.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  20. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Disconnect the battery: étape 20, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Disconnect the battery: étape 20, image 2 de 2
    • Use a spudger to pry up and disconnect the battery press connector.
  21. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Disconnect the earpiece speaker: étape 21, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Disconnect the earpiece speaker: étape 21, image 2 de 2
    • Use a spudger to pry up and disconnect the earpiece speaker press connector.
  22. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the earpiece speaker screws: étape 22, image 1 de 2 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the earpiece speaker screws: étape 22, image 2 de 2
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
  23. Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: étape 23, image 1 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: étape 23, image 2 de 3 Samsung Galaxy S24 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: étape 23, image 3 de 3
    • Insert the flat end of a spudger between the bottom edge of the earpiece speaker and the metal plate on the motherboard.
    • Twist the spudger to unclip the earpiece speaker from the frame and remove it.
    • During reassembly, insert the top edge of the earpiece speaker into the frame first before pressing down and clipping it back in.
Spencer Pennington
Membre depuis le 09/09/23
16 983 Réputation
113 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 425 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 45
Total : 334
