Aller au contenu principal
Samsung Galaxy Tab S3 Front Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Display: étape 1, image 1 de 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 2, image 1 de 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 4, image 1 de 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 4, image 2 de 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 4, image 3 de 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: étape 5, image 1 de 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: étape 5, image 2 de 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: étape 6, image 1 de 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 7, image 1 de 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 8, image 1 de 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 8, image 2 de 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 8, image 3 de 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 9, image 1 de 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 9, image 2 de 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 10, image 1 de 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 10, image 2 de 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 11, image 1 de 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: étape 12, image 1 de 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: étape 12, image 2 de 3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: étape 12, image 3 de 3
    • Using a nylon spudger, carefully push the camera out of its framing.
    • Unlike the rear facing camera, you will be pushing this camera out from the front. Try to push on the side of the camera so as to not damage the lens with the pointy end of the spudger.
  13. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 13, image 1 de 2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 13, image 2 de 2
    • Carefully pop the front facing camera off from the motherboard with the flat end of the spudger.
  14. Samsung Galaxy Tab S3 Front Facing Camera Replacement: étape 14, image 1 de 1
    • Remove the front facing camera from the device.
Justin Ogihara
Membre depuis le 09/18/17
27 209 Réputation
52 tutoriels rédigés
Équipe
EDU Team Membre de l'équipe EDU Team
Staff
7 membres
637 tutoriels rédigés
Un commentaire
This repair can be done without removing the screen!
hansderaedt - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 13
Total : 371
