Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung RC512 Screen Replacement
Ce dont vous avez besoin
  1. Samsung RC512 Screen Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop upside down.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung RC512 Screen Replacement: étape 2, image 1 de 2 Samsung RC512 Screen Replacement: étape 2, image 2 de 2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
    Demander à FixBot
  3. Samsung RC512 Screen Replacement, Screen: étape 3, image 1 de 3 Samsung RC512 Screen Replacement, Screen: étape 3, image 2 de 3 Samsung RC512 Screen Replacement, Screen: étape 3, image 3 de 3
    • The Laptop should be off before removing the battery.
    Demander à FixBot
  4. Samsung RC512 Screen Replacement: étape 4, image 1 de 3 Samsung RC512 Screen Replacement: étape 4, image 2 de 3 Samsung RC512 Screen Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
    Demander à FixBot
  5. Samsung RC512 Screen Replacement: étape 5, image 1 de 2 Samsung RC512 Screen Replacement: étape 5, image 2 de 2
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
    Demander à FixBot
  6. Samsung RC512 Screen Replacement: étape 6, image 1 de 2 Samsung RC512 Screen Replacement: étape 6, image 2 de 2
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
    Demander à FixBot
  7. Samsung RC512 Screen Replacement: étape 7, image 1 de 3 Samsung RC512 Screen Replacement: étape 7, image 2 de 3 Samsung RC512 Screen Replacement: étape 7, image 3 de 3
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
    Demander à FixBot
jando
Membre depuis le 09/15/16
917 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 18-2, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 1,065
