Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Watch Active Sensor Array Replacement
Ce dont vous avez besoin
    1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: étape 1, image 1 de 2 Samsung Watch Active Sensor Array Replacement, Turn off the watch: étape 1, image 2 de 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: étape 2, image 1 de 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Demander à FixBot
    3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: étape 3, image 1 de 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: étape 3, image 2 de 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: étape 3, image 3 de 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Demander à FixBot
    4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: étape 4, image 1 de 2 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: étape 4, image 2 de 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Demander à FixBot
    5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: étape 5, image 1 de 1
      • Remove the back cover.
      Demander à FixBot
    1. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: étape 6, image 1 de 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: étape 6, image 2 de 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: étape 6, image 3 de 3
      • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
      • Carefully twist the opening pick to separate the sensor array from the back cover.
      Demander à FixBot
    2. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: étape 7, image 1 de 2 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: étape 7, image 2 de 2
      • Remove the sensor array from the back cover.
      Demander à FixBot
Tobias Isakeit
Membre depuis le 03/31/14
134 858 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 586 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 15
30 derniers jours : 65
Total : 4,935
