Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sonos One Power Adapter Replacement
Ce dont vous avez besoin
    1. Sonos One Power Adapter Replacement, Protective Cover: étape 1, image 1 de 3 Sonos One Power Adapter Replacement, Protective Cover: étape 1, image 2 de 3 Sonos One Power Adapter Replacement, Protective Cover: étape 1, image 3 de 3
      • Disconnect all power cords.
      • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
      • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
      Demander à FixBot
      Ajouter un commentaire
    2. Sonos One Power Adapter Replacement: étape 2, image 1 de 3 Sonos One Power Adapter Replacement: étape 2, image 2 de 3 Sonos One Power Adapter Replacement: étape 2, image 3 de 3
      • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
      Demander à FixBot
    3. Sonos One Power Adapter Replacement: étape 3, image 1 de 2 Sonos One Power Adapter Replacement: étape 3, image 2 de 2
      • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
      Demander à FixBot
    4. Sonos One Power Adapter Replacement: étape 4, image 1 de 3 Sonos One Power Adapter Replacement: étape 4, image 2 de 3 Sonos One Power Adapter Replacement: étape 4, image 3 de 3
      • The protective cover clip is very thin and deforms easily.
      • Remove the single 8mm Torx T10 screw and protective cover clip.
      Demander à FixBot
    5. Sonos One Power Adapter Replacement: étape 5, image 1 de 2 Sonos One Power Adapter Replacement: étape 5, image 2 de 2
      • Slide the protective cover upwards to remove.
      Demander à FixBot
    1. Sonos One Power Adapter Replacement, Control Panel & Microphone: étape 6, image 1 de 3 Sonos One Power Adapter Replacement, Control Panel & Microphone: étape 6, image 2 de 3 Sonos One Power Adapter Replacement, Control Panel & Microphone: étape 6, image 3 de 3
      • Use the pointed end of a spudger to remove the covers that hide the screws.
      • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
      Demander à FixBot
    2. Sonos One Power Adapter Replacement: étape 7, image 1 de 2 Sonos One Power Adapter Replacement: étape 7, image 2 de 2
      • With the front of the unit facing you, lift the control panel up using your thumbs.
      • There's a ribbon cable attaching the control panel to the speaker so work slowly.
      Demander à FixBot
    3. Sonos One Power Adapter Replacement: étape 8, image 1 de 3 Sonos One Power Adapter Replacement: étape 8, image 2 de 3 Sonos One Power Adapter Replacement: étape 8, image 3 de 3
      • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
      • Pull the control panel ribbon cable out of its socket.
      Demander à FixBot
    4. Sonos One Power Adapter Replacement: étape 9, image 1 de 2 Sonos One Power Adapter Replacement: étape 9, image 2 de 2
      • Pull the control panel away from the speaker to separate.
      Demander à FixBot
    1. Sonos One Power Adapter Replacement, Power Adapter Receptacle: étape 10, image 1 de 3 Sonos One Power Adapter Replacement, Power Adapter Receptacle: étape 10, image 2 de 3 Sonos One Power Adapter Replacement, Power Adapter Receptacle: étape 10, image 3 de 3
      • Remove the six 9mm Torx T8 screws from the motherboard panel.
      Demander à FixBot
    2. Sonos One Power Adapter Replacement: étape 11, image 1 de 2 Sonos One Power Adapter Replacement: étape 11, image 2 de 2
      • Using a plastic opening tool, separate the motherboard from the speaker.
      Demander à FixBot
    3. Sonos One Power Adapter Replacement: étape 12, image 1 de 3 Sonos One Power Adapter Replacement: étape 12, image 2 de 3 Sonos One Power Adapter Replacement: étape 12, image 3 de 3
      • Using your thumb, disconnect the speaker cable from the motherboard.
      Demander à FixBot
    4. Sonos One Power Adapter Replacement: étape 13, image 1 de 3 Sonos One Power Adapter Replacement: étape 13, image 2 de 3 Sonos One Power Adapter Replacement: étape 13, image 3 de 3
      • Disconnect the power adapter plug from the motherboard using your thumb.
      Demander à FixBot
    5. Sonos One Power Adapter Replacement: étape 14, image 1 de 3 Sonos One Power Adapter Replacement: étape 14, image 2 de 3 Sonos One Power Adapter Replacement: étape 14, image 3 de 3
      • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
      Demander à FixBot
    6. Sonos One Power Adapter Replacement: étape 15, image 1 de 2 Sonos One Power Adapter Replacement: étape 15, image 2 de 2
      • Remove the motherboard panel from the speaker housing.
      Demander à FixBot
    7. Sonos One Power Adapter Replacement: étape 16, image 1 de 3 Sonos One Power Adapter Replacement: étape 16, image 2 de 3 Sonos One Power Adapter Replacement: étape 16, image 3 de 3
      • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
      • Remove the two 9mm Torx T8 screws from the power adapter plug.
      • Remove the power adapter receptacle from its housing slot.
      Demander à FixBot
9 autres ont terminé cette réparation.
Marcus Glowa
Membre depuis le 02/14/18
1 134 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 membres
24 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 37
30 derniers jours : 140
Total : 10,352
