Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony SRS-XB43 LED Module Replacement
Ce dont vous avez besoin
  1. Sony SRS-XB43 LED Module Replacement, Faceplate: étape 1, image 1 de 2 Sony SRS-XB43 LED Module Replacement, Faceplate: étape 1, image 2 de 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
    Demander à FixBot
    Ajouter un commentaire
  2. Sony SRS-XB43 LED Module Replacement: étape 2, image 1 de 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
    Demander à FixBot
  3. Sony SRS-XB43 LED Module Replacement: étape 3, image 1 de 1
    • Remove all ten screws using a Phillips #1 screwdriver.
    Demander à FixBot
  4. Sony SRS-XB43 LED Module Replacement: étape 4, image 1 de 2 Sony SRS-XB43 LED Module Replacement: étape 4, image 2 de 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
    Demander à FixBot
  5. Sony SRS-XB43 LED Module Replacement, Battery: étape 5, image 1 de 2 Sony SRS-XB43 LED Module Replacement, Battery: étape 5, image 2 de 2
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
    Demander à FixBot
  6. Sony SRS-XB43 LED Module Replacement: étape 6, image 1 de 3 Sony SRS-XB43 LED Module Replacement: étape 6, image 2 de 3 Sony SRS-XB43 LED Module Replacement: étape 6, image 3 de 3
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
    Demander à FixBot
  7. Sony SRS-XB43 LED Module Replacement: étape 7, image 1 de 2 Sony SRS-XB43 LED Module Replacement: étape 7, image 2 de 2
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
    Demander à FixBot
  8. Sony SRS-XB43 LED Module Replacement: étape 8, image 1 de 2 Sony SRS-XB43 LED Module Replacement: étape 8, image 2 de 2
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
    Demander à FixBot
  9. Sony SRS-XB43 LED Module Replacement, LED Module: étape 9, image 1 de 1
    • Orient the motherboard chassis so that the battery compartment is facing upwards.
    • Identify the two LED control PCBs located on the left and right edges of the plastic chassis.
    Demander à FixBot
  10. Sony SRS-XB43 LED Module Replacement: étape 10, image 1 de 3 Sony SRS-XB43 LED Module Replacement: étape 10, image 2 de 3 Sony SRS-XB43 LED Module Replacement: étape 10, image 3 de 3
    • Identify the black latch on each of the plugs that are connected to the PBCs.
    • Swing the black latch open by gently prying the front/extruding lip of the plug with a spudger or other flat tool.
    • To give a sense of direction, the latch should swing away from you or towards the LED (metallic square).
    • Grab each ribbon cable and apply a horizontal pulling force (with respect to the LED control PCBs) to disconnect them from the connectors.
    Demander à FixBot
  11. Sony SRS-XB43 LED Module Replacement: étape 11, image 1 de 3 Sony SRS-XB43 LED Module Replacement: étape 11, image 2 de 3 Sony SRS-XB43 LED Module Replacement: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Insert the spudger below the LED control PCBs and pry to remove it from the plastic chassis.
    • The PCBs are held onto the chassis with a considerably strong double-sided tape. If the spudger is too thick and can not fit under the PCBs, use a thin plastic pick or plastic card.
    Demander à FixBot
2 autres ont terminé cette réparation.
Isaac Oliveira
Membre depuis le 10/26/22
282 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Membre de l'équipe UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 membres
10 tutoriels rédigés
1 commentaire de tutoriel
i need email to contact You please
Danny Bryan Vega - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 43
Total : 964
