Aller au contenu principal
Pour réparer ensemble - Je crée un compte
TMY V08 Lens Replacement
Ce dont vous avez besoin
  1. TMY V08 Lens Replacement, Top Panel: étape 1, image 1 de 3 TMY V08 Lens Replacement, Top Panel: étape 1, image 2 de 3 TMY V08 Lens Replacement, Top Panel: étape 1, image 3 de 3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
    Demander à FixBot
    Ajouter un commentaire
  2. TMY V08 Lens Replacement: étape 2, image 1 de 3 TMY V08 Lens Replacement: étape 2, image 2 de 3 TMY V08 Lens Replacement: étape 2, image 3 de 3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
    Demander à FixBot
  3. TMY V08 Lens Replacement, Lens: étape 3, image 1 de 3 TMY V08 Lens Replacement, Lens: étape 3, image 2 de 3 TMY V08 Lens Replacement, Lens: étape 3, image 3 de 3
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
    Demander à FixBot
  4. TMY V08 Lens Replacement: étape 4, image 1 de 2 TMY V08 Lens Replacement: étape 4, image 2 de 2
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
    Demander à FixBot
  5. TMY V08 Lens Replacement: étape 5, image 1 de 3 TMY V08 Lens Replacement: étape 5, image 2 de 3 TMY V08 Lens Replacement: étape 5, image 3 de 3
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
    Demander à FixBot
  6. TMY V08 Lens Replacement: étape 6, image 1 de 2 TMY V08 Lens Replacement: étape 6, image 2 de 2
    • Flip the projector over so the bottom is facing up.
    • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
    Demander à FixBot
  7. TMY V08 Lens Replacement: étape 7, image 1 de 2 TMY V08 Lens Replacement: étape 7, image 2 de 2
    • Flip the projector back over.
    • Remove the fine gauge adjustment, by lifting it out.
    Demander à FixBot
  8. TMY V08 Lens Replacement: étape 8, image 1 de 3 TMY V08 Lens Replacement: étape 8, image 2 de 3 TMY V08 Lens Replacement: étape 8, image 3 de 3
    • Grasp the side of the lens.
    • Pull the lens outward away from the hole while pulling upward to remove the lens.
    Demander à FixBot
Lesli
Membre depuis le 10/02/23
321 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 74
Total : 1,546
