Aller au contenu principal
Toshiba Satellite U840W 12V Charging Port Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: étape 1, image 1 de 2 Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: étape 1, image 2 de 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W 12V Charging Port Replacement: étape 2, image 1 de 3 Toshiba Satellite U840W 12V Charging Port Replacement: étape 2, image 2 de 3 Toshiba Satellite U840W 12V Charging Port Replacement: étape 2, image 3 de 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W 12V Charging Port Replacement: étape 3, image 1 de 3 Toshiba Satellite U840W 12V Charging Port Replacement: étape 3, image 2 de 3 Toshiba Satellite U840W 12V Charging Port Replacement: étape 3, image 3 de 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W 12V Charging Port Replacement: étape 4, image 1 de 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W 12V Charging Port Replacement, 12V Charging Port: étape 6, image 1 de 1
    • Remove the connector from the motherboard.
    • This separates the only connection from the motherboard to the cover.
  6. Toshiba Satellite U840W 12V Charging Port Replacement: étape 7, image 1 de 1
    • Remove the screw holding 12v charging port to the cover.
  7. Toshiba Satellite U840W 12V Charging Port Replacement: étape 8, image 1 de 1
    • Remove the 12v charging port from the cover.
2 autres ont terminé cette réparation.
Joshua Pedersen
Membre depuis le 02/04/19
217 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G1, Saknee Spring 2019 Membre de l'équipe Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 263
