Toshiba Satellite U840W 12V Charging Port Replacement
Introduction
Passez à l'étape 1Removing this piece makes working inside of the computer easier. To replace this part (if it is broken) follow this guide.
Ce dont vous avez besoin
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
2 autres ont terminé cette réparation.
