Aller au contenu principal
Toshiba Satellite U840W Speakers Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite U840W Speakers Replacement, Toshiba Satellite U840W Disassembly Guide: étape 1, image 1 de 2 Toshiba Satellite U840W Speakers Replacement, Toshiba Satellite U840W Disassembly Guide: étape 1, image 2 de 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Speakers Replacement: étape 2, image 1 de 3 Toshiba Satellite U840W Speakers Replacement: étape 2, image 2 de 3 Toshiba Satellite U840W Speakers Replacement: étape 2, image 3 de 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Speakers Replacement: étape 3, image 1 de 3 Toshiba Satellite U840W Speakers Replacement: étape 3, image 2 de 3 Toshiba Satellite U840W Speakers Replacement: étape 3, image 3 de 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Speakers Replacement: étape 4, image 1 de 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W Speakers Replacement, Speakers: étape 6, image 1 de 2 Toshiba Satellite U840W Speakers Replacement, Speakers: étape 6, image 2 de 2
    • Remove the two 5mm screws using a Phillips #00 screwdriver.
    • Remove the left speaker.
  6. Toshiba Satellite U840W Speakers Replacement: étape 7, image 1 de 3 Toshiba Satellite U840W Speakers Replacement: étape 7, image 2 de 3 Toshiba Satellite U840W Speakers Replacement: étape 7, image 3 de 3
    • Remove tape holding the speaker wire.
    • Follow length of wire to the connector while removing the tape.
    • Remove connector.
  7. Toshiba Satellite U840W Speakers Replacement: étape 8, image 1 de 1
    • Follow steps "6" and "7" to remove the right speaker.
Thomas Marlett
Membre depuis le 02/04/19
242 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G1, Saknee Spring 2019 Membre de l'équipe Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 347
