Aller au contenu principal
Whirlpool Refrigerator Freezer Thermistor Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: étape 2, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: étape 2, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: étape 3, image 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: étape 3, image 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: étape 4, image 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement: étape 4, image 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: étape 5, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: étape 5, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: étape 5, image 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
    Those fins are sharp....wear gloves!
    David B Hinton - Réponse
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: étape 6, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: étape 6, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: étape 6, image 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: étape 7, image 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: étape 7, image 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: étape 7, image 3 de 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: étape 8, image 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: étape 8, image 2 de 2
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: étape 9, image 1 de 1
    • Remove the thermistor.
    Does anyone know this part number
    Tony - Réponse
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: étape 10, image 1 de 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
702 tutoriels rédigés
Un commentaire
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 85
Total : 2,581
