Introduction
Follow the steps in this guide to remove or transfer the earpiece speaker and front sensor assembly in your iPhone 12. This assembly is affixed to the back of the display and also includes a microphone, ambient light sensor, flood illuminator, and proximity sensor.
This assembly is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement.
The flood illuminator forms part of the biometric Face ID security feature, and Face ID functions will fail if the original component is damaged or incorrectly installed. Replacing it with a new part will also cause Face ID to fail, so take extra care not to damage any of these components during this procedure. If damaged, only Apple or an “Apple authorized” technician can restore Face ID function.
Ce dont vous avez besoin
Power off your iPhone before beginning disassembly.
Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Outil utilisé dans cette étape :Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
Continue sliding up the right edge of the iPhone until you reach the top right corner.
Leave the pick in the top right corner before continuing.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
Leave the pick in the top left corner before continuing.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Insert a second opening pick in the bottom left corner of the iPhone.
Twist both picks simultaneously until the left edge clips release.
Rotate your iPhone so the right edge faces you.
Open the iPhone by swinging the display up from the right side, like the front cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a spudger or a fingernail to disconnect the display cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Use a Y000 driver to remove four screws securing the front sensor connector cover.
Three 1.1 mm long screws
One 1.4 mm long screw
Swing the cover up from the left until the small clip on the right unhooks.
Remove the cover.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Remove the four screws securing the speaker/sensor assembly to the back of the display.
Two 1.4 mm long Phillips screws
One 1.7 mm long shouldered Y000 screw
One 1.2 mm long Y000 screw
Use the point of a spudger to gently pry up the top edge of the speaker.
Flip the speaker assembly over—down and away from the top edge of the display.
Use a hair dryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
Use the point of a spudger to lift and separate the ambient light sensor from its notch in the front panel.
Continue sliding the spudger underneath the ambient light sensor and its cable to separate the adhesive securing the cable.
Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
Use the point of a spudger to lift the proximity sensor and flood illuminator module out of its notch in the front panel.
Remove the earpiece speaker and front sensor assembly.
Proximity sensor
Flood illuminator
The module must be positioned so that these components are not obstructed by any adhesive.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Answers community for help.
9 autres ont terminé cette réparation.
2 commentaires
The title of this Guide is "iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement". The text and photos ONLY SHOW DISASSEMBLY AND THERE IS NO GUIDE ON REASSEMBLY...ESPECIALLY THE DETAIL OF HOW THE PART IS REATTACHED TO THE SCREEN! My experience of this guide is that it is a 50% proposition and is not helpful.
RP
Finally someone said it, any one that’s doing something like this as a beginner is kinda screwed with reassembly the whole in reverse doesn’t work with visual people
Jesse -
