Aller au contenu principal
Vidéo d'introduction
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iPhone 14 Pro Max, utilisez notre manuel de réparation.
  1. iPhone 14 Pro Max Chip ID, Top-most layer: étape 1, image 1 de 2 iPhone 14 Pro Max Chip ID, Top-most layer: étape 1, image 2 de 2
    • Chip ID part 1:
    • SanDisk SDMVGKLK2 128G 128 GB NAND flash memory
    • Apple/Dialog Semiconductor 338S00819-A1 power management
    • Likely Apple/Cirrus Logic 338S00843 voice processor
    • Apple/Cirrus Logic 338S00537 audio amplifier
    • Likely Apple/Dialog Semiconductor 338S0081C ? power management
    • Texas Instruments TPS61280H DC-DC converter
    • Maybe STMicroelectronics EEPROM
    Since when has SanDisk been producing NAND flash memories for iPhones?
    Atti - Réponse
  2. iPhone 14 Pro Max Chip ID: étape 2, image 1 de 1
    • Chip ID part 2:
    • Possibly Infineon load switch
    • NXP Semiconductor NTB0101GS1 1-bit translating transceiver
    • Texas Instruments LSF0101 1-bit bidirectional voltage level translator
  3. iPhone 14 Pro Max Chip ID: étape 3, image 1 de 1
    • Chip ID part 3:
    • WiFi/Bluetooth Module (possibly)
    Avgo/broadcom
    Anj Syd - Réponse
  4. iPhone 14 Pro Max Chip ID, Underside of the top-most layer: étape 4, image 1 de 2 iPhone 14 Pro Max Chip ID, Underside of the top-most layer: étape 4, image 2 de 2
    • Chip ID part 1:
    • Apple APL1W10/339S01104 A16 64-bit hexa-core applications processor w/ penta-core GPU layered underneath most likely Samsung K3LK2K20CM-EGCP 6 GB LPDDR5 SDRAM memory
    • Apple APL109A/338S00942 power management
    • Apple/Dialog Semiconductor 338S00839-B0 power management
    • Broadcom BCM59365EA1IUBG wireless power receiver
    • STMicroelectronics STB601A05 power management
    • Texas Instruments TPS65657B0 display power supply
    BCM59365EA1IUBG It's lab controller, not wireless
    Denys Kolomiiets - Réponse
    Ok, WTH happened at the lower left corner of the power management chip? Being a bit overzealous with the heat to open the case? Several components are shifted.
    Steffen Barabasch - Réponse
  5. iPhone 14 Pro Max Chip ID: étape 5, image 1 de 1
    • Chip ID part 2:
    • Texas Instruments LM3567A1 LED flash driver
    • Apple/Cirrus Logic 338S00738 audio codec
    • Likely Analog Devices taptic engine driver
    • Texas Instruments CD3710A1 VCSEL array driver
    • NXP Semiconductor CBTL1618A0 DisplayPort multiplexer
    • Texas Instruments USB 2.0 dual repeater
    • onsemi DC-DC converter
  6. iPhone 14 Pro Max Chip ID: étape 6, image 1 de 1
    • Chip ID part 3:
    • Likely onsemi DC-DC converter
    • Possibly STMicroelectronics serial EEPROM memory
  7. iPhone 14 Pro Max Chip ID: étape 7, image 1 de 1
    • Chip ID part 4:
    • Likely USI UWB module
    • Broadcom AFEM-8245 front-end module
  8. iPhone 14 Pro Max Chip ID, Sandwich layer: étape 8, image 1 de 2 iPhone 14 Pro Max Chip ID, Sandwich layer: étape 8, image 2 de 2
    • Chip ID part 1:
    • STMicroelectronics ST33J secure element
    • Qualcomm PMX65 power management
    • Qualcomm QET7100 envelope tracker
    • Probably Qualcomm PMK65 clock generator
    • Likely Qorvo envelope tracker
    • Possibly STMicroelectronics power management
  9. iPhone 14 Pro Max Chip ID: étape 9, image 1 de 1
    • Chip ID part 2:
    • NXP Semiconductor SN210V NFC controller w/ secure element
    • Satellite module (possibly)
    • Qualcomm SDX65M X65 5G modem
    • Qualcomm SDR735 RF transceiver
    • Qualcomm SMR546 RF transceiver
    • Broadcom AFEM-8231 front-end module
    • Skyworks SKY58290-20 front-end module
    Qulacomm SMR546 RF should be at left side, this is a mistake.
    xiajinggai - Réponse
  10. iPhone 14 Pro Max Chip ID: étape 10, image 1 de 1
    • Chip ID part 3:
    • Broadcom AFEM-8240 front-end module
    • Likely Skyworks SKY58853-17 ? front-end module
    • Possibly Skyworks SKY52628 antenna switch module
    • Possibly Skyworks SKY5xx92-16 power amplifier module
  11. iPhone 14 Pro Max Chip ID: étape 11, image 1 de 1
    • Chip ID part 4 - sensors:
    • Bosch Sensortec 6-axis accelerometer/gyroscope
    Beside BOSCH's 6轴加速计/陀螺仪 sensor, there is no Magnetic sensor ? or it's still using Alps HSCDTD00xA as ecompass? Thanks!
    Leo Chen - Réponse
  12. iPhone 14 Pro Max Chip ID, Bottom layer: étape 12, image 1 de 2 iPhone 14 Pro Max Chip ID, Bottom layer: étape 12, image 2 de 2
    • Antennas:
    • Connector to possibly the satellite antenna
    • 5G mmWave patch antenna
    Il est possible que la 5g puisse pas plus fonctionné
    Rorotech - Réponse
15 commentaires
Are the 14 Pro/Max using TLC or QLC NAND?
boris_dg - Réponse
Nobody idea?
boris_dg -
Possibly TLC, but so far I know, the NADA on pro and pro max at least from 3 suppliers. Hope no QLC
Tyrael Lee -
Do all models have the satellite hardware or only the US model? Would be a shame if they can't add more countries for the SOS feature because the hardware is missing.
Which chip is responsible for the new dual frequency GPS? Is there an additional GPS antenna for L5 band? Improved GPS in all models? Because sadly I see absolutely no GPS accuracy improvement in Switzerland with 14 Pro Max compared to 13 Pro Max (using iOS 16.0.1).
So many questions. Hope they can be answered. Tnx for your great work iFixit team!
Marcel Burkhalter - Réponse
Qualcomm SDR735 RF transceiver might include GPS(GNSS) L1+L5 support.
洪小福 -
who made the 5G mmWave antena
kv1180 - Réponse
Probably Murata or USI vendor
洪小福 -
Is iPhone14/plus also have X65 modem?
asuka suzumiya - Réponse
Probably the old X60.
boris_dg -
If based on X60. how to connect with satellites?
asuka suzumiya -
I don't think that particular chip has something to do with Satelite.
boris_dg -
But in iphone14 teardown article, ifixit said: "we can confirm that the satellite connectivity is powered by a new Qualcomm X65 modem, which adds new 2.4 GHz n53 band capabilities to support Globalstar."
asuka suzumiya -
So if the modem is carrying this functionality, than should be X65.
boris_dg -
Yes, Qualcomm SDX65M is on board, very clearly.
xiajinggai -
how to switch motherboard 14 pro to 14 pro max?
Артем Дмитриев - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 31
7 derniers jours : 220
30 derniers jours : 898
Total : 71,039
