Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 15 Plus Taptic Engine Replacement
Ce dont vous avez besoin
  1. iPhone 15 Plus Taptic Engine Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Demander à FixBot
    Ajouter un commentaire
  2. iPhone 15 Plus Taptic Engine Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Tape over any cracks: étape 2, image 2 de 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Demander à FixBot
  3. iPhone 15 Plus Taptic Engine Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Mark your opening picks: étape 3, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Demander à FixBot
  4. iPhone 15 Plus Taptic Engine Replacement, Remove the pentalobe screws: étape 4, image 1 de 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Demander à FixBot
  5. iPhone 15 Plus Taptic Engine Replacement, Heat the bottom edge: étape 5, image 1 de 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Demander à FixBot
  6. iPhone 15 Plus Taptic Engine Replacement, Insert an opening pick: étape 6, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Insert an opening pick: étape 6, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    Demander à FixBot
  7. iPhone 15 Plus Taptic Engine Replacement, Back glass information: étape 7, image 1 de 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    Demander à FixBot
  8. iPhone 15 Plus Taptic Engine Replacement, Separate the bottom edge adhesive: étape 8, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the bottom edge adhesive: étape 8, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the bottom edge adhesive: étape 8, image 3 de 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Demander à FixBot
  9. iPhone 15 Plus Taptic Engine Replacement, Heat the right edge: étape 9, image 1 de 1
    • Heat the right edge of the back glass until it's hot to the touch.
    Demander à FixBot
  10. iPhone 15 Plus Taptic Engine Replacement, Separate the bottom right corner adhesive: étape 10, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the bottom right corner adhesive: étape 10, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the bottom right corner adhesive: étape 10, image 3 de 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Demander à FixBot
  11. iPhone 15 Plus Taptic Engine Replacement, Heat the left edge: étape 11, image 1 de 1
    • Heat the left edge of the back glass until it's hot to the touch.
    Demander à FixBot
  12. iPhone 15 Plus Taptic Engine Replacement, Separate the left edge adhesive: étape 12, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the left edge adhesive: étape 12, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the left edge adhesive: étape 12, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
    Demander à FixBot
  13. iPhone 15 Plus Taptic Engine Replacement, Heat the top edge: étape 13, image 1 de 1
    • Heat the top edge of the back glass until it's hot to the touch.
    Demander à FixBot
  14. iPhone 15 Plus Taptic Engine Replacement, Separate the top edge adhesive: étape 14, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the top edge adhesive: étape 14, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the top edge adhesive: étape 14, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
    Demander à FixBot
  15. iPhone 15 Plus Taptic Engine Replacement, Heat the top right corner: étape 15, image 1 de 1
    • Heat the top right corner of the back glass until it's hot to the touch.
    Demander à FixBot
  16. iPhone 15 Plus Taptic Engine Replacement, Separate the top right corner adhesive: étape 16, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the top right corner adhesive: étape 16, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Separate the top right corner adhesive: étape 16, image 3 de 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
    Demander à FixBot
  17. iPhone 15 Plus Taptic Engine Replacement, Swing open the back glass: étape 17, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Swing open the back glass: étape 17, image 2 de 2
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
    Demander à FixBot
  18. iPhone 15 Plus Taptic Engine Replacement, Unfasten the lower connector cover: étape 18, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Unfasten the lower connector cover: étape 18, image 2 de 2
    Outil utilisé dans cette étape :
    FixMat
    $31.41
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
    Demander à FixBot
  19. iPhone 15 Plus Taptic Engine Replacement, Remove the lower connector cover: étape 19, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement, Remove the lower connector cover: étape 19, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement, Remove the lower connector cover: étape 19, image 3 de 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    Demander à FixBot
  20. iPhone 15 Plus Taptic Engine Replacement: étape 20, image 1 de 3 iPhone 15 Plus Taptic Engine Replacement: étape 20, image 2 de 3 iPhone 15 Plus Taptic Engine Replacement: étape 20, image 3 de 3
    • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    Demander à FixBot
  21. iPhone 15 Plus Taptic Engine Replacement, Unfasten the Taptic Engine connector cover: étape 21, image 1 de 1
    • Use your Phillips #000 driver to remove the four screws securing the Taptic Engine and its connector cover:
    • One 1.4 mm‑long screw
    • One 1.9 mm‑long screw (larger screw head)
    • One 1.9 mm‑long screw (smaller screw head)
    • One 2.1 mm‑long screw
    Demander à FixBot
  22. iPhone 15 Plus Taptic Engine Replacement, Remove the cover: étape 22, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Remove the cover: étape 22, image 2 de 2
    • Use tweezers to remove the Taptic Engine connector cover.
    • During reassembly, orient the cover so that its gold spring contact is closest to the edge of the frame.
    Demander à FixBot
  23. iPhone 15 Plus Taptic Engine Replacement, Disconnect the Taptic Engine: étape 23, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Disconnect the Taptic Engine: étape 23, image 2 de 2
    • Use the point of your spudger to pry up and disconnect the Taptic Engine press connector.
    Demander à FixBot
  24. iPhone 15 Plus Taptic Engine Replacement, Unfasten the Taptic Engine: étape 24, image 1 de 1
    Standoff Screwdriver for iPhones
    $5.49
    • Use a standoff driver to remove the 3.3 mm screw securing the top left of the Taptic Engine.
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
    Demander à FixBot
  25. iPhone 15 Plus Taptic Engine Replacement, Remove the Taptic Engine: étape 25, image 1 de 2 iPhone 15 Plus Taptic Engine Replacement, Remove the Taptic Engine: étape 25, image 2 de 2
    • Use tweezers or your fingers to remove the Taptic Engine.
    Demander à FixBot
To reassemble your phone, follow these instructions in reverse order.
Clay Eickemeyer
Membre depuis le 09/19/22
104 240 Réputation
472 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
17 854 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 82
Total : 1,698
