Aller au contenu principal
iPhone 16 Plus Battery Replacement
Ce dont vous avez besoin
  1. iPhone 16 Plus Battery Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 iPhone 16 Plus Battery Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Plus Battery Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 16 Plus Battery Replacement, Tape over any cracks: étape 2, image 2 de 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Plus Battery Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone 16 Plus Battery Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone 16 Plus Battery Replacement, Mark your opening picks: étape 3, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Plus Battery Replacement, Remove the pentalobe screws: étape 4, image 1 de 2 iPhone 16 Plus Battery Replacement, Remove the pentalobe screws: étape 4, image 2 de 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the USB-C port.
  5. iPhone 16 Plus Battery Replacement, Secure the screen: étape 5, image 1 de 3 iPhone 16 Plus Battery Replacement, Secure the screen: étape 5, image 2 de 3 iPhone 16 Plus Battery Replacement, Secure the screen: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next five steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
    • Make sure the tape is only securing the screen, and not the back glass.
  6. iPhone 16 Plus Battery Replacement, Secure an Anti-Clamp: étape 6, image 1 de 3 iPhone 16 Plus Battery Replacement, Secure an Anti-Clamp: étape 6, image 2 de 3 iPhone 16 Plus Battery Replacement, Secure an Anti-Clamp: étape 6, image 3 de 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 16 Plus Battery Replacement: étape 7, image 1 de 3 iPhone 16 Plus Battery Replacement: étape 7, image 2 de 3 iPhone 16 Plus Battery Replacement: étape 7, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 16 Plus Battery Replacement, Heat the bottom edge: étape 8, image 1 de 2 iPhone 16 Plus Battery Replacement, Heat the bottom edge: étape 8, image 2 de 2
    • Heat your iOpener and apply it to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp do the work for you, repeating this process as necessary.
  9. iPhone 16 Plus Battery Replacement, Insert an opening pick: étape 9, image 1 de 3 iPhone 16 Plus Battery Replacement, Insert an opening pick: étape 9, image 2 de 3 iPhone 16 Plus Battery Replacement, Insert an opening pick: étape 9, image 3 de 3
    • Insert the tip of an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  10. iPhone 16 Plus Battery Replacement, Heat the bottom edge: étape 10, image 1 de 2 iPhone 16 Plus Battery Replacement, Heat the bottom edge: étape 10, image 2 de 2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
  11. iPhone 16 Plus Battery Replacement, Insert an opening pick: étape 11, image 1 de 3 iPhone 16 Plus Battery Replacement, Insert an opening pick: étape 11, image 2 de 3 iPhone 16 Plus Battery Replacement, Insert an opening pick: étape 11, image 3 de 3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
  12. iPhone 16 Plus Battery Replacement, Back glass information: étape 12, image 1 de 2 iPhone 16 Plus Battery Replacement, Back glass information: étape 12, image 2 de 2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  13. iPhone 16 Plus Battery Replacement, Separate the bottom edge adhesive: étape 13, image 1 de 3 iPhone 16 Plus Battery Replacement, Separate the bottom edge adhesive: étape 13, image 2 de 3 iPhone 16 Plus Battery Replacement, Separate the bottom edge adhesive: étape 13, image 3 de 3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contacts.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  14. iPhone 16 Plus Battery Replacement, Heat the right edge: étape 14, image 1 de 2 iPhone 16 Plus Battery Replacement, Heat the right edge: étape 14, image 2 de 2
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
  15. iPhone 16 Plus Battery Replacement, Separate the bottom right corner adhesive: étape 15, image 1 de 3 iPhone 16 Plus Battery Replacement, Separate the bottom right corner adhesive: étape 15, image 2 de 3 iPhone 16 Plus Battery Replacement, Separate the bottom right corner adhesive: étape 15, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the spring contacts and ribbon cable.
    • Slide your pick around the bottom right corner and slide it halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  16. iPhone 16 Plus Battery Replacement, Heat the left edge: étape 16, image 1 de 2 iPhone 16 Plus Battery Replacement, Heat the left edge: étape 16, image 2 de 2
  17. iPhone 16 Plus Battery Replacement, Separate the left edge adhesive: étape 17, image 1 de 3 iPhone 16 Plus Battery Replacement, Separate the left edge adhesive: étape 17, image 2 de 3 iPhone 16 Plus Battery Replacement, Separate the left edge adhesive: étape 17, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the left edge to avoid damaging the spring contact.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  18. iPhone 16 Plus Battery Replacement, Heat the top edge: étape 18, image 1 de 2 iPhone 16 Plus Battery Replacement, Heat the top edge: étape 18, image 2 de 2
    • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
    • When using a hair dryer or heat gun, heat until it's hot to the touch.
  19. iPhone 16 Plus Battery Replacement, Separate the top edge adhesive: étape 19, image 1 de 3 iPhone 16 Plus Battery Replacement, Separate the top edge adhesive: étape 19, image 2 de 3 iPhone 16 Plus Battery Replacement, Separate the top edge adhesive: étape 19, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You should hear and feel clicks as the top two clips release.
  20. iPhone 16 Plus Battery Replacement, Swing open the back glass: étape 20, image 1 de 2 iPhone 16 Plus Battery Replacement, Swing open the back glass: étape 20, image 2 de 2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
  21. iPhone 16 Plus Battery Replacement, Unfasten the middle connector cover: étape 21, image 1 de 2 iPhone 16 Plus Battery Replacement, Unfasten the middle connector cover: étape 21, image 2 de 2
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the middle connector cover.
  22. iPhone 16 Plus Battery Replacement, Remove the middle connector cover: étape 22, image 1 de 2 iPhone 16 Plus Battery Replacement, Remove the middle connector cover: étape 22, image 2 de 2
    • Be careful not to dent or puncture the battery during this step.
    • Use blunt-nose tweezers or your fingers to slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
    • During reassembly, align the hooks over their slots on the logic board. Then, press the cover down and slide it towards the right edge to re-engage the hooks.
  23. iPhone 16 Plus Battery Replacement, Disconnect the battery: étape 23, image 1 de 3 iPhone 16 Plus Battery Replacement, Disconnect the battery: étape 23, image 2 de 3 iPhone 16 Plus Battery Replacement, Disconnect the battery: étape 23, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip or the flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  24. iPhone 16 Plus Battery Replacement, Disconnect the wireless charger: étape 24, image 1 de 2 iPhone 16 Plus Battery Replacement, Disconnect the wireless charger: étape 24, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  25. iPhone 16 Plus Battery Replacement, Remove the back glass: étape 25, image 1 de 2 iPhone 16 Plus Battery Replacement, Remove the back glass: étape 25, image 2 de 2
    • Lift the back glass off the frame and remove it.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass (before replacing the adhesive), power on your phone, and make sure it works as expected. Power it back down, disconnect the battery, and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  26. iPhone 16 Plus Battery Replacement, Assemble the VoltClip: étape 26, image 1 de 2 iPhone 16 Plus Battery Replacement, Assemble the VoltClip: étape 26, image 2 de 2
    • Plug the VoltClip's barrel connector into the USB-C elbow.
    • Don't connect the VoltClip to a power source just yet. The loose alligator clips may accidentally touch each other and cause an electrical short.
  27. iPhone 16 Plus Battery Replacement, Peel up the silver tab: étape 27, image 1 de 2 iPhone 16 Plus Battery Replacement, Peel up the silver tab: étape 27, image 2 de 2
    • Use a clean fingernail or an opening pick to peel up the silver tab at the bottom edge of the battery.
  28. iPhone 16 Plus Battery Replacement, Attach the alligator clips: étape 28, image 1 de 2 iPhone 16 Plus Battery Replacement, Attach the alligator clips: étape 28, image 2 de 2
    • Attach the red alligator clip to the silver tab on the battery.
  29. iPhone 16 Plus Battery Replacement: étape 29, image 1 de 3 iPhone 16 Plus Battery Replacement: étape 29, image 2 de 3 iPhone 16 Plus Battery Replacement: étape 29, image 3 de 3
    • Attach the black alligator clip to the grounding screw.
  30. iPhone 16 Plus Battery Replacement, Connect power to the VoltClip: étape 30, image 1 de 3 iPhone 16 Plus Battery Replacement, Connect power to the VoltClip: étape 30, image 2 de 3 iPhone 16 Plus Battery Replacement, Connect power to the VoltClip: étape 30, image 3 de 3
    • Make sure the red alligator clip isn't touching any stray metallic surfaces.
    • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
  31. iPhone 16 Plus Battery Replacement, Disconnect the VoltClip: étape 31, image 1 de 3 iPhone 16 Plus Battery Replacement, Disconnect the VoltClip: étape 31, image 2 de 3 iPhone 16 Plus Battery Replacement, Disconnect the VoltClip: étape 31, image 3 de 3
    • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
  32. iPhone 16 Plus Battery Replacement, Remove the battery: étape 32, image 1 de 3 iPhone 16 Plus Battery Replacement, Remove the battery: étape 32, image 2 de 3 iPhone 16 Plus Battery Replacement, Remove the battery: étape 32, image 3 de 3
    • Your adhesive should be fully loosened at this point. If your battery doesn't budge during the step, reconnect the VoltClip for an additional minute and try again.
    • Grip the silver tab and lift the battery out of the frame.
    • Alternatively, you can use a suction handle to pull the battery out. If the battery doesn't come out easily, don't force it—reconnect the VoltClip for one minute.
To reassemble your phone, follow these instructions in reverse order.
After your repair, run Apple's Repair Assistant. Navigate to Settings  General  About  Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Plus Answers Community for help.
Nick Schultz
Membre depuis le 03/24/24
15 772 Réputation
87 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 410 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 87
30 derniers jours : 406
Total : 1,786
