Aller au contenu principal
iPhone 16 Plus Screen Replacement
Ce dont vous avez besoin
  1. iPhone 16 Plus Screen Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 iPhone 16 Plus Screen Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Plus Screen Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 16 Plus Screen Replacement, Tape over any cracks: étape 2, image 2 de 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Plus Screen Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone 16 Plus Screen Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone 16 Plus Screen Replacement, Mark your opening picks: étape 3, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Plus Screen Replacement, Remove the pentalobe screws: étape 4, image 1 de 2 iPhone 16 Plus Screen Replacement, Remove the pentalobe screws: étape 4, image 2 de 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the USB-C port.
  5. iPhone 16 Plus Screen Replacement, Apply tape: étape 5, image 1 de 3 iPhone 16 Plus Screen Replacement, Apply tape: étape 5, image 2 de 3 iPhone 16 Plus Screen Replacement, Apply tape: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next five steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the screen, you need to secure the back glass with tape.
    • Cut two strips of tape, apply them along the long edges of the back of the phone, and fold them over the back glass to secure it. If you have suction tape, fold it over the short edge of the back glass when applying (the edge with the USB-C port).
    • Make sure the tape is only securing the back glass, and not the screen.
  6. iPhone 16 Plus Screen Replacement, Secure an Anti-Clamp: étape 6, image 1 de 3 iPhone 16 Plus Screen Replacement, Secure an Anti-Clamp: étape 6, image 2 de 3 iPhone 16 Plus Screen Replacement, Secure an Anti-Clamp: étape 6, image 3 de 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the right edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 16 Plus Screen Replacement: étape 7, image 1 de 3 iPhone 16 Plus Screen Replacement: étape 7, image 2 de 3 iPhone 16 Plus Screen Replacement: étape 7, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 16 Plus Screen Replacement, Heat the bottom edge: étape 8, image 1 de 2 iPhone 16 Plus Screen Replacement, Heat the bottom edge: étape 8, image 2 de 2
    • Heat your iOpener and apply it to the bottom edge of the screen for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp do the work for you, repeating this process as necessary.
  9. iPhone 16 Plus Screen Replacement, Insert an opening pick: étape 9, image 1 de 3 iPhone 16 Plus Screen Replacement, Insert an opening pick: étape 9, image 2 de 3 iPhone 16 Plus Screen Replacement, Insert an opening pick: étape 9, image 3 de 3
    • Insert the tip of an opening pick into the gap between the screen and the frame.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  10. iPhone 16 Plus Screen Replacement, Heat the bottom edge: étape 10, image 1 de 2 iPhone 16 Plus Screen Replacement, Heat the bottom edge: étape 10, image 2 de 2
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  11. iPhone 16 Plus Screen Replacement, Insert an opening pick: étape 11, image 1 de 3 iPhone 16 Plus Screen Replacement, Insert an opening pick: étape 11, image 2 de 3 iPhone 16 Plus Screen Replacement, Insert an opening pick: étape 11, image 3 de 3
    • Apply a suction handle to the bottom edge of the screen, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  12. iPhone 16 Plus Screen Replacement, Screen information: étape 12, image 1 de 2 iPhone 16 Plus Screen Replacement, Screen information: étape 12, image 2 de 2
    • As you slice the adhesive securing the screen in the next eight steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the phone—one just above the Action button and the other about halfway between the volume down button and the bottom of the phone.
    • Multiple spring contacts around the perimeter of the phone.
  13. iPhone 16 Plus Screen Replacement, Separate the bottom adhesive: étape 13, image 1 de 3 iPhone 16 Plus Screen Replacement, Separate the bottom adhesive: étape 13, image 2 de 3 iPhone 16 Plus Screen Replacement, Separate the bottom adhesive: étape 13, image 3 de 3
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  14. iPhone 16 Plus Screen Replacement, Heat the right edge: étape 14, image 1 de 2 iPhone 16 Plus Screen Replacement, Heat the right edge: étape 14, image 2 de 2
  15. iPhone 16 Plus Screen Replacement, Separate the right adhesive: étape 15, image 1 de 2 iPhone 16 Plus Screen Replacement, Separate the right adhesive: étape 15, image 2 de 2
    • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
    • You'll hear and feel the metal clip release as you pass it.
  16. iPhone 16 Plus Screen Replacement, Heat the top edge: étape 16, image 1 de 2 iPhone 16 Plus Screen Replacement, Heat the top edge: étape 16, image 2 de 2
  17. iPhone 16 Plus Screen Replacement, Separate the top adhesive: étape 17, image 1 de 2 iPhone 16 Plus Screen Replacement, Separate the top adhesive: étape 17, image 2 de 2
    • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
  18. iPhone 16 Plus Screen Replacement, Heat the left edge: étape 18, image 1 de 2 iPhone 16 Plus Screen Replacement, Heat the left edge: étape 18, image 2 de 2
  19. iPhone 16 Plus Screen Replacement, Separate the left adhesive: étape 19, image 1 de 2 iPhone 16 Plus Screen Replacement, Separate the left adhesive: étape 19, image 2 de 2
    • Don't insert your pick deeper than 3 mm to avoid damaging the screen cables and the spring contacts.
    • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
  20. iPhone 16 Plus Screen Replacement, Prop up the screen: étape 20, image 1 de 3 iPhone 16 Plus Screen Replacement, Prop up the screen: étape 20, image 2 de 3 iPhone 16 Plus Screen Replacement, Prop up the screen: étape 20, image 3 de 3
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
  21. iPhone 16 Plus Screen Replacement, Remove the cover screws: étape 21, image 1 de 2 iPhone 16 Plus Screen Replacement, Remove the cover screws: étape 21, image 2 de 2
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
    • Use a tri-point Y000 driver to remove the 1 mm‑long screw securing the screen connector cover.
  22. iPhone 16 Plus Screen Replacement, Remove the screen connector covers: étape 22, image 1 de 3 iPhone 16 Plus Screen Replacement, Remove the screen connector covers: étape 22, image 2 de 3 iPhone 16 Plus Screen Replacement, Remove the screen connector covers: étape 22, image 3 de 3
    • Use tweezers or your fingers to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
    • Lift the cover out of its slot and remove it.
    • Repeat this process for the screen connector cover.
    • During reassembly, insert each cover at a 90-degree angle to re-engage the hook before laying it flat against the press connector.
  23. iPhone 16 Plus Screen Replacement, Disconnect the screen: étape 23, image 1 de 3 iPhone 16 Plus Screen Replacement, Disconnect the screen: étape 23, image 2 de 3 iPhone 16 Plus Screen Replacement, Disconnect the screen: étape 23, image 3 de 3
    • Use the tip of a spudger to pry up and disconnect the screen press connector.
    • Repeat this process for the front sensor press connector.
    • During reassembly, align each connector carefully over its socket and press down with your fingertip or flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  24. iPhone 16 Plus Screen Replacement, Remove the screen: étape 24, image 1 de 1
    • Lift the screen off of the frame and remove it.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
To reassemble your phone, follow this guide to reapply adhesive and install your screen.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Plus Answers Community for help.
Nick Schultz
Membre depuis le 03/24/24
15 772 Réputation
87 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 410 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 68
30 derniers jours : 234
Total : 1,188
