Introduction
Follow the steps in this guide to replace the lower flex cable in an iPhone 6s Plus. This cable assembly is home to the headphone jack and Lightning connector. If your phone is having trouble charging or connecting via USB, or you have a loose headphone jack, replacing this component can resolve your issue.
You can also use this guide to replace the lightning connector bracket.
Outils
Insert a SIM eject tool into the hole in the SIM tray.
Press to eject the SIM tray.
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
Use the point of a spudger to disconnect the Taptic Engine flex cable from the lower flex cable.
Prepare an iOpener and lay it across the bottom of the phone to soften the adhesive holding the Lightning connector flex cable in place.
Wait about a minute for the adhesive to soften before removing the iOpener and continuing.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 6s Plus Answers community for troubleshooting help.
154 autres ont terminé cette réparation.
23 commentaires
Hardest thing I have every done!! But well worth it. Now I know I need to go up on my labor price!!! :-) Thanks a ton from South Carolina!!
I just completed this repair, replacing the Headphone Jack/Lightening port, battery and iSight camera all at the same time. I removed everything as it explained in the guide, but can totally see how not removing the logic board would save time and isn't 100% necessary. I imagine that peeling the upper portion of the headphone/lighting port is slightly easier with the logic board removed, and you don't have to worry about that antenna cable. If I did it again, I would probably still remove the logic board.
you would have to be crazy to remove the board. just flip the speaker up on its back and rest against logic board. 20 mins should complete this . i cant stress enough that board or camera does not need removed . PERIOD
I completed this and it starts charging, but the home button stop working. It still sense my finger print, but it does not respond when i click on it.
Any help?
