Aller au contenu principal
iPhone SE 2022 Home/Touch ID Sensor Replacement
Ce dont vous avez besoin
  1. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the pentalobe screws: étape 1, image 2 de 2
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
  2. iPhone SE 2022 Home/Touch ID Sensor Replacement, Heat the front panel adhesive: étape 2, image 1 de 1
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. iPhone SE 2022 Home/Touch ID Sensor Replacement, Insert an opening pick: étape 3, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Insert an opening pick: étape 3, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  4. iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: étape 4, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: étape 4, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: étape 4, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: étape 5, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: étape 5, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the adhesive: étape 5, image 3 de 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. iPhone SE 2022 Home/Touch ID Sensor Replacement: étape 6, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement: étape 6, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement: étape 6, image 3 de 3
    • When you slice along the right edge, insert only the tip of the opening pick (~ 2–3 mm) to avoid damaging the display flex cables.
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Stop near the top right corner of the display.
  7. iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift the screen: étape 7, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift the screen: étape 7, image 2 de 2
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  8. iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the remaining adhesive: étape 8, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the remaining adhesive: étape 8, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Slice the remaining adhesive: étape 8, image 3 de 3
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  9. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disengage the front panel clips: étape 9, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disengage the front panel clips: étape 9, image 2 de 2
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  10. iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift up the display: étape 10, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift up the display: étape 10, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Lift up the display: étape 10, image 3 de 3
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • Remove the four Phillips screws securing the lower display cable bracket:
    • Two 1.2 mm-long screws
    • Two 2.8 mm-long screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  11. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the lower display cable bracket: étape 12, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the lower display cable bracket: étape 12, image 2 de 2
    • Use a pair of tweezers to carefully remove the lower display cable bracket.
  12. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the battery: étape 13, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the battery: étape 13, image 2 de 2
    • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
  13. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the display and digitizer cables: étape 14, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the display and digitizer cables: étape 14, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the display and digitizer cables: étape 14, image 3 de 3
    • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
    • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
    • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  14. iPhone SE 2022 Home/Touch ID Sensor Replacement, Unfasten the front sensor assembly bracket screws: étape 15, image 1 de 1
    • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
  15. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the front sensor assembly bracket: étape 16, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the front sensor assembly bracket: étape 16, image 2 de 2
    • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
  16. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the front sensor assembly cable: étape 17, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the front sensor assembly cable: étape 17, image 2 de 2
    • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
  17. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the display assembly: étape 18, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the display assembly: étape 18, image 2 de 2
    • Remove the display assembly.
  18. iPhone SE 2022 Home/Touch ID Sensor Replacement, Unfasten the home/Touch ID sensor bracket screws: étape 19, image 1 de 1
    • Remove the four screws securing the home/Touch ID sensor bracket:
    • Three 1.2 mm-long Y000 screws
    • One 1.1 mm-long Y000 screw
  19. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor bracket: étape 20, image 1 de 2 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor bracket: étape 20, image 2 de 2
    • Use a pair of tweezers to carefully remove the home/Touch ID sensor bracket.
  20. iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the home/Touch ID sensor: étape 21, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the home/Touch ID sensor: étape 21, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Disconnect the home/Touch ID sensor: étape 21, image 3 de 3
    • Use an opening tool to pry under the left edge of the home/Touch ID sensor cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of a spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
  21. iPhone SE 2022 Home/Touch ID Sensor Replacement, Heat the home/Touch ID sensor cable adhesive: étape 22, image 1 de 1
    • Prepare an iOpener and apply it to the screen where the home/Touch ID button is located for at least two minutes to loosen the adhesive underneath its cable.
  22. iPhone SE 2022 Home/Touch ID Sensor Replacement, Free the home/Touch ID sensor cable: étape 23, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Free the home/Touch ID sensor cable: étape 23, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Free the home/Touch ID sensor cable: étape 23, image 3 de 3
    • Carefully slide an opening pick underneath the home/Touch ID sensor cable and separate it from the back side of the display panel.
    • Avoid damaging the cable connector during this procedure. The home/Touch ID sensor cable is wrapped around it and abrupt movements might tear the connector cable. Try to fold the connector up in direction of the selfie camera and out of the cables way instead.
  23. iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor assembly: étape 24, image 1 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor assembly: étape 24, image 2 de 3 iPhone SE 2022 Home/Touch ID Sensor Replacement, Remove the home/Touch ID sensor assembly: étape 24, image 3 de 3
    • Use a pair of tweezers to remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
162 936 Réputation
649 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
140 membres
16 854 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 50
30 derniers jours : 234
Total : 1,539
