Aller au contenu principal
Remplacement de l'écran de l'iPhone 12 mini
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    If your iPhone 12 mini screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
    ***The combined earpiece speaker + sensor assembly affixed to the back of the display is paired to your individual iPhone from the factory***, so you must transfer it from your old display to your new one during any display replacement. It contains the flood illuminator, which is part of the biometric Face ID security feature. If it is damaged or replaced, Face ID will cease to function, so take extra care not to damage any of these components during this procedure. If damaged, only Apple or an Apple-authorized technician can restore Face ID function.
    ***Note***: On iOS 17.6 and earlier, True Tone functionality is disabled after a screen replacement, even when using an original Apple screen. AdditionallyOn iOS 18 and newer, you can calibrate your iPhone may temporarily show a warning about the “genuineness” of the displaynew screen using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true] to restore True Tone functionality on genuine screens purchased from Apple.
    You’ll need replacement adhesive to reattach components when reassembling the device.
      ***To reassemble your device, follow the above steps in reverse order.*** Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Check out our [link|https://www.ifixit.com/Answers/Device/iPhone%2012%20mini|iPhone 12 mini Answers community] for troubleshooting help.
      Étapes du tutoriel
