Aller au contenu principal
Changement batterie iPhone 14 Pro Max
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    Use this guide to replace a worn-out or dead battery in your iPhone 14 Pro Max.
    iPhone batteries are rated to hold 80% of their capacity for up to 500 charge cycles, which lasts roughly 18-24 months for most users. After that, your iPhone may need to be charged far more frequently, and iOS may warn you that performance is affected (in other words, your phone will run slower).
    This guide was created using the ***A2894*** (international) model. If you're fixing a different iPhone 14 Pro Max model, there may be some visual discrepancies, but the procedure should be the same.
    ***For your safety, discharge the battery below 25% before disassembling your device.*** This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
    ***Note***: After the repairOn iOS 17.6 and earlier, your iPhone may display a warning about the “genuineness” of the battery after the repair, even when using original Apple parts. If your iPhone functions normally, you can safely ignore the warning. On iOS 18 and newer, authenticate your new battery using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true].
    You’ll need replacement adhesive to reattach the battery and the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
      If possible, turn on your device and test your repair before installing new adhesive and resealing.
      ***To reassemble your device, follow these instructions in reverse order.*** During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      For optimal performance, [[Battery Calibration|calibrate your newly installed battery|new_window=true]] after completing this guide.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Ask/iPhone+14+Pro+Max|Answers community] for help.
      Étapes du tutoriel
      Étape 1 — Localiser les languettes d'extraction
      La batterie iPhone 14 Pro Max est fixée avec quatre bandes adhésives étirables à la coque arrière : deux sur le bord inférieur de la batterie et deux sur le bord supérieur.
      Étape 2 — Retirer les bandes adhésives étirables
      Attention : Ne perforez pas la batterie avec des outils pointus. Une batterie percée peut laisser échapper des produits chimiques dangereux ou prendre feu.
      Étape 3
      Saisissez la première languette avec vos doigts ou enroulez-la autour d'une spatule et éloignez-la de la batterie en tirant lentement vers le bas du téléphone.
      Étape 4
      Saisissez la deuxième languette avec vos doigts ou enroulez-la autour d'une spatule et éloignez-la de la batterie en tirant lentement vers le bas du téléphone.
      Étape 5
      Utilisez une pincette arrondie et un médiator pour décoller les deux languettes restantes du bord supérieur de la batterie.
      Étape 6
      Suivez la même procédure qu'avant pour retirer la troisième languette d'en dessous de la batterie. Veillez à ce qu'elle ne s'accroche à rien.
      Étape 7
      Retirez la dernière languette en suivant la même procédure. Faites attention à ce qu'elle ne s'accroche à rien.
      Étape 8 — Comment retirer une batterie coincée
      Si vous avez encore du mal à retirer la batterie, appliquez quelques gouttes d'alcool isopropylique (> 90 %) sous le bord de la batterie, à l'endroit où se trouvent la ou les bandes déchirées.
      Étape 9 — Retirer la batterie iPhone 14 Pro Max
      Ôtez la batterie.
