Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Traduction de l’étape 14
Étape 14
If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16.
Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
Flip the display data connector lock down onto the socket.
Insert the display power connector into its socket on the logic board.
- | [* black] Peel up and remove the backing from strips 15 and 14 on the display. |
+ | [* icon_note] ''At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.'' |
+ | [* black] If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16. |
+ | [* black] Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely. |
+ | [* black] Flip the display data connector lock down onto the socket. |
+ | [* black] Insert the display power connector into its socket on the logic board. |
