Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 32 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector. Slide the top of the bracket over the Touch ID cable connector from left to right.
  • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
  • Slide the top of the bracket over the Touch ID cable connector from left to right.
Lorsque vous remonterez votre iPhone, vous devrez réinstaller l'attache du câble de capteur d'empreintes (Touch ID). Il faut passer le haut de l'attache entre la batterie et le connecteur du câble Touch ID. L'avant doit passer par-dessus le connecteur.
Passez le dessus de l'attache par-dessus le connecteur de câble Touch ID en allant de gauche à droite.
[* icon_noteicon_reminder] During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, and thein front of the metal tab. The bottom must latch down over the connector.
[* icon_reminder] Slide the top of the bracket over the Touch ID cable connector from left to right.
