Aller au contenu principal
Remplacement de la vitre tactile de l'iPhone 5s
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 32 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
iPhone 5s Front Panel Assembly Replacement: étape 0, image 1 de 2 iPhone 5s Front Panel Assembly Replacement: étape 0, image 2 de 2
  • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
  • Slide the top of the bracket over the Touch ID cable connector from left to right.
  • Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
Lorsque vous remonterez votre iPhone, vous devrez réinstaller l'attache du câble de capteur d'empreintes (Touch ID). Il faut passer le haut de l'attache entre la batterie et le connecteur du câble Touch ID. L'avant doit passer par-dessus le connecteur.
Passez le dessus de l'attache par-dessus le connecteur de câble Touch ID en allant de gauche à droite.
[* icon_reminder] During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
[* icon_reminder] Slide the top of the bracket over the Touch ID cable connector from left to right.
+[* icon_note] Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
