Introduction
iPhone mini? iPhone 5se? 5s Plus? After a rather long rumor cycle, we finally have our hands on the new iPhone SE. Billed as a 5s with better specs, we're excited to see the perfect union of existing Apple tech in a new body. Kinda like Taco Bell—same ingredients, new menu item. Let's open it up and spill the beans!
Want to be the first to see inside the latest gadgets? Follow us on Facebook, Instagram, or Twitter for the latest news from the repair world.
Ce dont vous avez besoin
Vidéo d'introduction
Out with the old, and in with the new—hardware, that is. Here's the skinny on what's hiding behind that oh-so-familiar face:
Apple A9 processor with embedded M9 motion coprocessor
16 or 64 GB of storage
4-inch, 1136 x 640 pixels (326 ppi) Retina display
12 MP iSight camera supporting 4K video recording with 1.22 µ pixels, and a 1.2 MP ƒ/2.4 FaceTime HD camera
802.11a/b/g/n/ac Wi‑Fi + Bluetooth 4.2 + NFC + 19-band LTE
Touch ID sensor supporting user authentication and Apple Pay
Shifting our attention to the rose gold rear case, we spot the model number— A1662, never before seen in the wild.
Colors notwithstanding, in a side-by-side comparison, the SE is nearly indistinguishable from its predecessor.
One new feature we can spot is the matte chamfered edges around the display.
Outil utilisé dans cette étape :iSclack$24.99
Now for the step we don't like. Pentalobes: a five-pointed reminder that Apple doesn't really want you opening up your device.
Still, these pentalobes are totally cute and come in a matching rose gold.
Setting the pretty pink screws aside, we iSclack the top off—and there's no pesky, color-matching display adhesive in sight. Compared to Apple's S-series flagships, this opening procedure is a snap.
Just like in the iPhone 5s, lurking beneath the display of the SE we find the familiar Touch ID cable booby trap.
We're itching to do some comparisons and parts testing—but, safety first. Let's disconnect that battery!
No need to repeat the mistakes of the past—we've mastered these handy battery tabs!
The Li-ion battery in the iPhone SE comes in at 3.82 V, 6.21 Whr, and 1624 mAh. This offers a minor (but notable) capacity increase from the 1560 mAh cell in the 5s.
Next up, we pluck the upgraded rear-facing camera from its berth.
While it looks pretty similar to the one in the 5s (left), the SE's camera (right) has far fewer pins on its connector.
The SE's iSight camera gets a resolution bump up to 12 MP, but a decrease in pixel pitch down to 1.22µm from the 1.5µm pitch in the 5s.
We interrupt this teardown to bring you: more
cowbellteardown! -
Our friends at Creative Electron have been getting their teardown on, X-ray style!
We have for your enjoyment, three generations of iPhone 5 configurations.
Really, the only obvious change is the addition of the bi-metal Apple logo.
That, and the addition of the Touch ID cable between the 5 and 5s (unfortunate placement still intact in the SE, too).
Out speaker assembly, out vibrator, out SIM card and tray!
Rose gold remains SE exclusive though, so you may need to upgrade for proper color coordination.
Also of note: waterproof seals! There be foamy silicone seals surrounding some—but, mysteriously, not all—of the logic board connections.
We finally wrestle the Lightning connector assembly out of the
5sSE. -
It looks just like the 5s assembly, but the connectors are a smidge different; we couldn't get a 5s/SE swap to work out.
We pop the pesky rear connector off the logic board, and are free to scan the silicon fields of glory!
Apple A9 APL1022 SoC + SK Hynix 2 GB LPDDR4 RAM as denoted by the markings H9KNNNBTUMUMR-NLH
Qualcomm MDM9625M LTE Modem (as seen in iPhone 6/6 Plus)
Qualcomm WTR1625L RF Transceiver (as seen in iPhone 6/6 Plus)
Qualcomm QFE1100 Envelope Tracking IC (as seen in 6s/6s Plus, and 6/6 Plus)
Skyworks SKY77611 Quad-band Power Amplifier Module
There's even more silicon goodies on the reverse!
Toshiba THGBX5G7D2KLDXG 16 GB NAND Flash
339S00134 (likely an iteration of the Universal Scientific Industrial 339S00043 Wi-Fi module)
Apple/Dialog 338S00170 Power Management IC
NXP 66V10 NFC Controller and 1610A3 Charging IC (as seen in iPhone 6s/6s Plus)
Skyworks SKY77826 Ultra low-band Power Amplifier Duplexer and SKY77357 2G/EDGE Power Amplifier Module (likely an iteration of SKY77336)
Apple/Cirrus Logic 338S00105 and 338S1285 Audio ICs (as seen in iPhone 6s/6s Plus)
Qualcomm WFR1620 Receive-only Transceiver (as seen in iPhone 6/6 Plus)
Chip identification continued...
Avago ACPM-8020 Mid-band Power Amplifier Duplexer (as seen in iPhone 6 Plus)
Qorvo (TriQuint) TQF6410 Low-band Power Amplifier Duplexer (as seen in iPhone 6 Plus)
TDK EPCOS D5255 Diversity Receive Module
Qualcomm PM8019 PMIC (as seen in iPhone 6/6 Plus)
Qorvo (RF Micro Devices) RF5159 Antenna Switch Module (as seen in iPhone 6/6 Plus)
InvenSense EMS-A 6-axis Gyroscope and Accelerometer Combo
Broadcom BCM5976 Touchscreen Controller (first seen in iPhone 5)
iPhone SE Repairability: 6 out of 10 (10 is easiest to repair)
The display assembly is the first component out of the phone, simplifying screen replacements.
The battery is fairly easy to access, even though it's not technically "user replaceable."
The Touch ID cable could be easily ripped out of its socket if a user is not careful when opening the phone.
The iPhone SE still uses Pentalobe screws on the exterior, making it difficult to open without specialized tools.
123 commentaires de tutoriel
From your original picture, it appears the on/off switch in on the top. Is this correct? (I HATE the switch on the side).
Yup! The power button is in the same top position as it was in the 5s (and older) models.
Thanks for the clarity! I really hate the side on/off button placement on the 6's. Stupid.
Gail -
It needs to be on the side for the 6 and on as they are a lot bigger and it is ergonomically impossible to place the power button on the top or you'd have to stretch your finger to reach it. By the way I agree with you.
es-webb -
