Aller au contenu principal
Google Pixel 8 Pro Screen Replacement
Ce dont vous avez besoin
  1. Google Pixel 8 Pro Screen Replacement, Prepare your Pixel for disassembly: étape 1, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Prepare your Pixel for disassembly: étape 1, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Prepare your Pixel for disassembly: étape 1, image 3 de 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8 Pro Screen Replacement, Mark your opening picks: étape 2, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Mark your opening picks: étape 2, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Mark your opening picks: étape 2, image 3 de 3
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 8 Pro Screen Replacement, Heat the bottom edge adhesive: étape 3, image 1 de 1
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
  4. Google Pixel 8 Pro Screen Replacement, Secure the Anti-Clamp: étape 4, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Secure the Anti-Clamp: étape 4, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Secure the Anti-Clamp: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
  5. Google Pixel 8 Pro Screen Replacement, Twist the handle: étape 5, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Twist the handle: étape 5, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Twist the handle: étape 5, image 3 de 3
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  6. Google Pixel 8 Pro Screen Replacement, Insert an opening pick: étape 6, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Insert an opening pick: étape 6, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  7. Google Pixel 8 Pro Screen Replacement, Apply a suction cup: étape 7, image 1 de 2 Google Pixel 8 Pro Screen Replacement, Apply a suction cup: étape 7, image 2 de 2
    • Apply a suction handle to the center of the screen's bottom edge.
  8. Google Pixel 8 Pro Screen Replacement, Insert an opening pick: étape 8, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Insert an opening pick: étape 8, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Insert an opening pick: étape 8, image 3 de 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
  9. Google Pixel 8 Pro Screen Replacement, Prevent damage to your phone: étape 9, image 1 de 2 Google Pixel 8 Pro Screen Replacement, Prevent damage to your phone: étape 9, image 2 de 2
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  10. Google Pixel 8 Pro Screen Replacement, Separate the bottom edge adhesive: étape 10, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Separate the bottom edge adhesive: étape 10, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Separate the bottom edge adhesive: étape 10, image 3 de 3
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
  11. Google Pixel 8 Pro Screen Replacement, Heat the right edge adhesive: étape 11, image 1 de 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  12. Google Pixel 8 Pro Screen Replacement, Separate the right edge adhesive: étape 12, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Separate the right edge adhesive: étape 12, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Separate the right edge adhesive: étape 12, image 3 de 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  13. Google Pixel 8 Pro Screen Replacement, Leave a pick in the bottom left corner: étape 13, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Leave a pick in the bottom left corner: étape 13, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Leave a pick in the bottom left corner: étape 13, image 3 de 3
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  14. Google Pixel 8 Pro Screen Replacement, Heat the left edge adhesive: étape 14, image 1 de 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  15. Google Pixel 8 Pro Screen Replacement, Separate the left edge adhesive: étape 15, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Separate the left edge adhesive: étape 15, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Separate the left edge adhesive: étape 15, image 3 de 3
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  16. Google Pixel 8 Pro Screen Replacement, Heat the top edge adhesive: étape 16, image 1 de 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  17. Google Pixel 8 Pro Screen Replacement, Separate the top edge adhesive: étape 17, image 1 de 2 Google Pixel 8 Pro Screen Replacement, Separate the top edge adhesive: étape 17, image 2 de 2
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
  18. Google Pixel 8 Pro Screen Replacement, Prop up the screen: étape 18, image 1 de 2 Google Pixel 8 Pro Screen Replacement, Prop up the screen: étape 18, image 2 de 2
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
  19. Google Pixel 8 Pro Screen Replacement, Remove the screen cable cover: étape 19, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Remove the screen cable cover: étape 19, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Remove the screen cable cover: étape 19, image 3 de 3
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
  20. Google Pixel 8 Pro Screen Replacement, Disconnect the screen: étape 20, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Disconnect the screen: étape 20, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Disconnect the screen: étape 20, image 3 de 3
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  21. Google Pixel 8 Pro Screen Replacement, Reassembly information: étape 21, image 1 de 3 Google Pixel 8 Pro Screen Replacement, Reassembly information: étape 21, image 2 de 3 Google Pixel 8 Pro Screen Replacement, Reassembly information: étape 21, image 3 de 3
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Use the pull tabs to remove the liners covering the front camera cutout, the back of the screen, and the perimeter adhesive.
    • Reconnect the screen cable and reinstall its cover.
    • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membre depuis le 09/14/22
55 333 Réputation
408 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
137 membres
17 457 tutoriels rédigés
8 commentaires
So i tried the replacement but only my 4, 5, 6 buttons press... I reordered a new screen but is there something i did wrong or break?
Jody-Ann Byfield - Réponse
before you apply the new screen, make sure the plastic housing also came off with the screen! the one that keeps the camera in place.
If you've done it correctly the camera should be kind of loose and not held in.
Same issue as the pixel 7 pro new screen does not fit!
The guide does not mention this and assumes that all of it will come off in one go. I've wasted an adhesive on this and a few hours spent scratching my head, if this isnt removed then your screen wont click in.
samuel howell - Réponse
Hi Samuel, thank you for your comment! We'd like to update the guide to be more helpful, but just need some clarifying information. Is the housing you're talking about the small, square housing on the top of the screen, or the entire perimeter housing?
Spencer Day -
It would be nice if ifixit made picks with a physical stop so they don't slide in more than 3mm. I would imagine this would be useful for more than the Pixel phones.
megadirk - Réponse
once the new screen is placed, whenever the phone wakes up (including notifications), there is a 1 sec sharp yellow light flashed and the screen becomes normal. Does anyone has this issue after applied the new screen?
Hui Peter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 46
7 derniers jours : 371
30 derniers jours : 1,289
Total : 8,292
