Aller au contenu principal
Google Pixel 7a Earpiece Speaker Replacement
Ce dont vous avez besoin
  1. Google Pixel 7a Earpiece Speaker Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
  2. Google Pixel 7a Earpiece Speaker Replacement, Soften the adhesive: étape 2, image 1 de 1
    • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
    • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
  3. Google Pixel 7a Earpiece Speaker Replacement, Secure an Anti-Clamp: étape 3, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Secure an Anti-Clamp: étape 3, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Secure an Anti-Clamp: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
    • Squeeze the cups together to create suction.
  4. Google Pixel 7a Earpiece Speaker Replacement, Use the Anti-Clamp to create a gap: étape 4, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Use the Anti-Clamp to create a gap: étape 4, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Use the Anti-Clamp to create a gap: étape 4, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  5. Google Pixel 7a Earpiece Speaker Replacement, Insert an opening pick using the Anti-Clamp: étape 5, image 1 de 1
    • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
    • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
    • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
    • Insert an opening pick into the gap between the rear cover and the frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
    • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
  6. Google Pixel 7a Earpiece Speaker Replacement, Insert an opening pick using a suction handle: étape 6, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Insert an opening pick using a suction handle: étape 6, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Insert an opening pick using a suction handle: étape 6, image 3 de 3
    • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
    • Apply a suction handle to the center of the bottom edge of the rear cover.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  7. Google Pixel 7a Earpiece Speaker Replacement, Adhesive information: étape 7, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Adhesive information: étape 7, image 2 de 2
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
  8. Google Pixel 7a Earpiece Speaker Replacement, Angle the opening pick: étape 8, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Angle the opening pick: étape 8, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Angle the opening pick: étape 8, image 3 de 3
    • Angle the opening pick upward so the tip faces away from the frame.
    • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
    • Slide your pick to the bottom left corner of the rear cover.
    • Leave this pick in place to prevent the adhesive from resealing.
  9. Google Pixel 7a Earpiece Speaker Replacement, Separate the bottom edge adhesive: étape 9, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Separate the bottom edge adhesive: étape 9, image 2 de 2
    • Insert a second opening pick in the bottom left corner.
    • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
  10. Google Pixel 7a Earpiece Speaker Replacement, Soften the right edge adhesive: étape 10, image 1 de 1
    • Apply a heated iOpener to the right edge of the rear cover for two minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
  11. Google Pixel 7a Earpiece Speaker Replacement, Separate the right edge adhesive: étape 11, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the right edge adhesive: étape 11, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the right edge adhesive: étape 11, image 3 de 3
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a third opening pick in the bottom right corner of the rear cover.
    • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
  12. Google Pixel 7a Earpiece Speaker Replacement, Soften the left edge adhesive: étape 12, image 1 de 1
    • Apply a heated iOpener to the left edge of the rear cover for two minutes.
  13. Google Pixel 7a Earpiece Speaker Replacement, Separate the left edge adhesive: étape 13, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the left edge adhesive: étape 13, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the left edge adhesive: étape 13, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid damaging the wireless charging coil and rear cover foam pad.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom left corner of the rear cover.
    • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
  14. Google Pixel 7a Earpiece Speaker Replacement, Soften the top edge adhesive: étape 14, image 1 de 1
    • Apply a heated iOpener to the top edge of the rear cover for two minutes.
  15. Google Pixel 7a Earpiece Speaker Replacement, Separate the antenna bracket adhesive: étape 15, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the antenna bracket adhesive: étape 15, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the antenna bracket adhesive: étape 15, image 3 de 3
    • There's a thick strip of adhesive along the antenna housing.
    • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
    • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
    • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
  16. Google Pixel 7a Earpiece Speaker Replacement, Separate the remaining top edge adhesive: étape 16, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the remaining top edge adhesive: étape 16, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Separate the remaining top edge adhesive: étape 16, image 3 de 3
    • Pull your opening pick out to a depth of 3 mm.
    • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
    • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
  17. Google Pixel 7a Earpiece Speaker Replacement, Rotate your top edge opening picks: étape 17, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Rotate your top edge opening picks: étape 17, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Rotate your top edge opening picks: étape 17, image 3 de 3
    • Remember to angle your picks upward and away from the frame during this step.
    • Roll the top edge pick so its flat edge is under the rear cover.
    • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
  18. Google Pixel 7a Earpiece Speaker Replacement, Pry up the camera bar: étape 18, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Pry up the camera bar: étape 18, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Pry up the camera bar: étape 18, image 3 de 3
    • There's a long strip of adhesive securing the rear cover below the camera bar.
    • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
    • Pry back and forth until the camera bar loosens.
    • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
  19. Google Pixel 7a Earpiece Speaker Replacement, Finish separating the adhesive: étape 19, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Finish separating the adhesive: étape 19, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Finish separating the adhesive: étape 19, image 3 de 3
    • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
  20. Google Pixel 7a Earpiece Speaker Replacement, Remove the rear cover: étape 20, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Remove the rear cover: étape 20, image 2 de 2
    • Remove the rear cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your rear cover.
  21. Google Pixel 7a Earpiece Speaker Replacement, Soften the flash unit adhesive: étape 21, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Soften the flash unit adhesive: étape 21, image 2 de 2
    • Apply a heated iOpener to the flash unit for one minute to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use a hair dryer or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  22. Google Pixel 7a Earpiece Speaker Replacement, Separate the flash unit adhesive: étape 22, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Separate the flash unit adhesive: étape 22, image 2 de 2
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • Slide your pick under the right edge of the flash to separate the adhesive securing it to the cover.
  23. Google Pixel 7a Earpiece Speaker Replacement, Clean the logic board cover: étape 23, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Clean the logic board cover: étape 23, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Clean the logic board cover: étape 23, image 3 de 3
    J'achète
    • If the copper tape lifted away with the flash, use tweezers or your fingers to remove the black foam residue from the logic board cover.
  24. Google Pixel 7a Earpiece Speaker Replacement, Remove the old copper tape: étape 24, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Remove the old copper tape: étape 24, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Remove the old copper tape: étape 24, image 3 de 3
    • Be careful not to damage the battery with your tool during this step.
    • Apply a heated iOpener to the underside of the flash for one minute.
    • Hold the neck of the flash cable steady and use tweezers to peel and remove the copper tape from the flash unit.
    • If the copper tape stayed on the logic board cover and you have a replacement, remove the old tape now.
  25. Google Pixel 7a Earpiece Speaker Replacement, Reassembly information: étape 25, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Reassembly information: étape 25, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Reassembly information: étape 25, image 3 de 3
    • Make sure the small foam spacer is still in the middle of the flash recess in the logic board cover. If not, stick it back to the middle.
    • Peel the copper tape from the large adhesive liner.
    • Place the copper tape face-down onto the flash, with the cutout toward the neck of the cable.
    • Remove the blue liner to expose the adhesive.
    • Press the flash into place.
  26. Google Pixel 7a Earpiece Speaker Replacement, Unfasten the logic board cover: étape 26, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Unfasten the logic board cover: étape 26, image 2 de 2
    • While the Pixel 7a uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx driver to remove the thirteen 4.3 mm 3IP Torx Plus screws securing the logic board cover.
    • Use a T2 Torx driver to remove the 1.5 mm 1IP Torx Plus screw securing the right edge of the cover.
  27. Google Pixel 7a Earpiece Speaker Replacement, Unclip the logic board cover: étape 27, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Unclip the logic board cover: étape 27, image 2 de 2
    • Insert an opening pick between the bottom right corner of the logic board cover and the frame.
    • Pry up to release the clip securing the cover.
  28. Google Pixel 7a Earpiece Speaker Replacement, Free the flash unit: étape 28, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Free the flash unit: étape 28, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Free the flash unit: étape 28, image 3 de 3
    • Slowly lift the top edge of the logic board and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board into place.
  29. Google Pixel 7a Earpiece Speaker Replacement, Remove the wireless charging assembly: étape 29, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Remove the wireless charging assembly: étape 29, image 2 de 2
    • Remove the wireless charging assembly.
  30. Google Pixel 7a Earpiece Speaker Replacement, Remove the connector cover: étape 30, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Remove the connector cover: étape 30, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Remove the connector cover: étape 30, image 3 de 3
    J'achète
    • Use your T2 Torx driver to remove the 1.5 mm 1IP Torx Plus screw securing the connector cover.
    • Use tweezers or your fingers to remove the cover.
    • During reassembly, place the upper left corner of the cover under the hook on the logic board before installing its screw.
  31. Google Pixel 7a Earpiece Speaker Replacement: étape 31, image 1 de 1
    • The Verizon model (G0DZQ) Google Pixel 7a has an extra cable and connector for the 5G mmWave antenna. Unless otherwise mentioned, the rest of the guide procedure is the same for either type of phone.
  32. Google Pixel 7a Earpiece Speaker Replacement, Disconnect the battery: étape 32, image 1 de 2 Google Pixel 7a Earpiece Speaker Replacement, Disconnect the battery: étape 32, image 2 de 2
    • Insert the flat end of a spudger under the top edge of the battery press connector.
    • Pry straight up to disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  33. Google Pixel 7a Earpiece Speaker Replacement, Unfasten the earpiece speaker: étape 33, image 1 de 1
    • Use your T3 Torx driver to remove the 4.3 mm 3IP Torx Plus screw securing the earpiece speaker to the frame.
  34. Google Pixel 7a Earpiece Speaker Replacement, Remove the earpiece speaker: étape 34, image 1 de 3 Google Pixel 7a Earpiece Speaker Replacement, Remove the earpiece speaker: étape 34, image 2 de 3 Google Pixel 7a Earpiece Speaker Replacement, Remove the earpiece speaker: étape 34, image 3 de 3
    • Lift the bottom edge of the earpiece speaker upward.
    • Pull the speaker toward the bottom of the phone to free the red gasket from its cutout in the frame.
    • Remove the speaker.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Clay Eickemeyer
Membre depuis le 09/19/22
67 432 Réputation
453 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 430 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 51
Total : 754
