Aller au contenu principal
Lenovo ThinkPad T470 Fan and Heat Sink Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T470 Fan and Heat Sink Replacement, External Battery: étape 1, image 1 de 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, External Battery: étape 1, image 2 de 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, External Battery: étape 1, image 3 de 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 2, image 3 de 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Bottom Cover: étape 3, image 1 de 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Bottom Cover: étape 3, image 2 de 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 4, image 3 de 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 5, image 1 de 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Fan and Heat Sink: étape 6, image 1 de 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement, Fan and Heat Sink: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  7. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 7, image 2 de 2
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Secure the screws using the same cross-pattern when reassembling the heatsink and fan.
  8. Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 8, image 1 de 2 Lenovo ThinkPad T470 Fan and Heat Sink Replacement: étape 8, image 2 de 2
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
Kristen Gismondi
Membre depuis le 11/12/14
82 368 Réputation
200 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 303 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 55
Total : 2,278
