Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 15" Retina Display Mid 2014 Feet Replacement
Ce dont vous avez besoin
    1. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement, Lower Case: étape 1, image 1 de 1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.1 mm
      • Two 2.3 mm
      Demander à FixBot
      Ajouter un commentaire
    2. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 2, image 1 de 2 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 2, image 2 de 2
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      Demander à FixBot
    3. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 3, image 1 de 3 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 3, image 2 de 3 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 3, image 3 de 3
      • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
      • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
      Demander à FixBot
    1. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement, Feet: étape 4, image 1 de 2 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement, Feet: étape 4, image 2 de 2
      • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
      • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
      Demander à FixBot
    2. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 5, image 1 de 2 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 5, image 2 de 2
      Outil utilisé dans cette étape :
      • Remove any broken or damaged feet.
      • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
      • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
      Demander à FixBot
    3. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 6, image 1 de 1
      • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
      Demander à FixBot
    4. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 7, image 1 de 1
      • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
      Demander à FixBot
    5. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 8, image 1 de 1
      • Peel a replacement foot from the plastic backing.
      • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
      Demander à FixBot
    6. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 9, image 1 de 3 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 9, image 2 de 3 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 9, image 3 de 3
      • Align the new foot inside the cavity.
      • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
      • You may want to use a pencil to lightly mark where the alignment nub is located. Be careful not to scratch the lower case with your pencil.
      • Lay the foot down while keeping it properly aligned.
      • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
      Demander à FixBot
    7. MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 10, image 1 de 2 MacBook Pro 15" Retina Display Mid 2014 Feet Replacement: étape 10, image 2 de 2
      • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
      • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
      • Repeat the last seven steps for any remaining broken or worn feet.
      Demander à FixBot
19 autres ont terminé cette réparation.
Taylor Dixon
Membre depuis le 06/26/18
72 686 Réputation
94 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 14
30 derniers jours : 80
Total : 11,861
