Aller au contenu principal
Motorola Droid Turbo 2 Midframe Replacement
Ce dont vous avez besoin
  1. Motorola Droid Turbo 2 Midframe Replacement, Midframe: étape 1, image 1 de 3 Motorola Droid Turbo 2 Midframe Replacement, Midframe: étape 1, image 2 de 3 Motorola Droid Turbo 2 Midframe Replacement, Midframe: étape 1, image 3 de 3
    • Power off your phone before you begin working.
    • Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • Remove the SIM card tray assembly from the phone.
  2. Motorola Droid Turbo 2 Midframe Replacement: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the top edge of the phone for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Droid Turbo 2 Midframe Replacement: étape 3, image 1 de 2 Motorola Droid Turbo 2 Midframe Replacement: étape 3, image 2 de 2
    • Angle an opening pick and firmly press so that it slips under the back cover.
    • Depending on the age of the phone, this can be difficult. Additional heating with the iOpener may help. You can pry carefully with a metal spudger to create a gap for the opening pick.
  4. Motorola Droid Turbo 2 Midframe Replacement: étape 4, image 1 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 4, image 2 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 4, image 3 de 3
    • Slide the opening pick along the top edge of the phone to break up the adhesive.
    • Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
  5. Motorola Droid Turbo 2 Midframe Replacement: étape 5, image 1 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 5, image 2 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 5, image 3 de 3
    • Repeat the iOpener heating and slicing procedures for the remaining three sides.
    • Make sure to cut into the deeper areas as the back cover is held on by a large adhesive surface.
  6. Motorola Droid Turbo 2 Midframe Replacement: étape 6, image 1 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 6, image 2 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 6, image 3 de 3
    • Once you have cut through the adhesive, slowly peel the back cover away from the frame.
    • Remove the back cover.
    • During reassembly, follow this rear cover adhesive guide to properly apply the pre-cut adhesive strip.
  7. Motorola Droid Turbo 2 Midframe Replacement: étape 7, image 1 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 7, image 2 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 7, image 3 de 3
    • Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
    • To reinstall the cover, align the cover and use your finger to push it forward into place.
  8. Motorola Droid Turbo 2 Midframe Replacement: étape 8, image 1 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 8, image 2 de 3 Motorola Droid Turbo 2 Midframe Replacement: étape 8, image 3 de 3
    • Use the point of a spudger to pry up and remove the coil connector rubber cover.
  9. Motorola Droid Turbo 2 Midframe Replacement: étape 9, image 1 de 2 Motorola Droid Turbo 2 Midframe Replacement: étape 9, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the flash connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  10. Motorola Droid Turbo 2 Midframe Replacement: étape 10, image 1 de 2 Motorola Droid Turbo 2 Midframe Replacement: étape 10, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
  11. Motorola Droid Turbo 2 Midframe Replacement: étape 11, image 1 de 1
    • Remove the following T3 screws securing the midframe:
    • Thirteen 3.1 mm black screws
    • Four 4.3 mm silver screws
    • Due to screw and bit variance, you may have better luck with a T4 driver. The proper bit should seat fully in the screwhead and feel slightly loose. The bit should not feel like it's stuck in the screwhead.
  12. Motorola Droid Turbo 2 Midframe Replacement: étape 12, image 1 de 2 Motorola Droid Turbo 2 Midframe Replacement: étape 12, image 2 de 2
    • Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
  13. Motorola Droid Turbo 2 Midframe Replacement: étape 13, image 1 de 2 Motorola Droid Turbo 2 Midframe Replacement: étape 13, image 2 de 2
    • Remove the midframe from the phone.
    • You can tape over the side buttons to prevent them from falling out during your repair.
    • If the buttons fall out of the midframe, reinsert them in the orientation as shown before you reinstall the midframe.
Repair didn’t go as planned? Check out our Motorola Moto Droid Turbo 2 Answers community for troubleshooting help.
4 autres ont terminé cette réparation.
Arthur Shi
Membre depuis le 01/03/18
253 346 Réputation
526 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 182 tutoriels rédigés
3 commentaires
Other than the comments I left above, I felt this was a nice simple-to-follow guide that gives me confidence to try this myself.
If you fix the items listed above, it will be perfect.
Thanks!
pj.catania - Réponse
Good post and the extra comments help.
Jane Doe - Réponse
Where can I buy a good T3 screwdriver?
I have tried 3 brands and the screwdriver rounds off instead of removing the screw.
David Peterson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 13
Total : 7,572
