Introduction
Use this guide to replace the battery on your Samsung Galaxy Note20 Ultra.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
Use a Phillips screwdriver to remove the five 4.0 mm screws securing the loudspeaker to the frame.
Insert the pointed end of a spudger into the hole marked by a triangle on the left side of the loudspeaker.
Use the spudger to pry up and loosen the left side of the loudspeaker.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the open spaces in each corner of the battery.
Wait two minutes for the isopropyl alcohol to weaken the adhesive underneath the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
15 autres ont terminé cette réparation.
4 commentaires
where did you buy the new battery from?
What is the precut adhesive card used for?
Thank you so much!!! My battery was starting to bulge badly. While the life was still satisfactory, the shape of my phone was beginning to become very distorted, the side buttons no longer worked properly in my DBrand case, and when I pressed my finger on the fingerprint sensor, my screen would depress and click. Not only did you offer the battery and tools needed, but a perfect guide to installing it. Simply amazing.
I just wish you would lose the ridiculous communist imagery on your branding. Repairing products is not communist, it just makes sense. Let's make right to repair an American virtue again, and not model the movement off some Maoist revolution.
Just want to note, I bought the precut adhesive, and battery adhesive from this guide, only to start looking around more and find that Ifixit also sells the note 20 ultra 5G precut adhesive so you don't need to deal with putting the precut adhesive strips around the edge.
Fun note, it also comes with the battery adhesive, so now I have an extra battery adhesive, as well as precut tape strips that I probably will never use, or if I do use, will probably never be able to find them... lol
