Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPad 8 LTE Button Control Cable Replacement
Ce dont vous avez besoin
  1. iPad 8 LTE Button Control Cable Replacement, Heat the left edge: étape 1, image 1 de 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
    Demander à FixBot
    Ajouter un commentaire
  2. iPad 8 LTE Button Control Cable Replacement, Screen removal information: étape 2, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Screen removal information: étape 2, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Screen removal information: étape 2, image 3 de 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
    Demander à FixBot
  3. iPad 8 LTE Button Control Cable Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    Demander à FixBot
  4. iPad 8 LTE Button Control Cable Replacement: étape 4, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 4, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 4, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Demander à FixBot
  5. iPad 8 LTE Button Control Cable Replacement: étape 5, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 5, image 2 de 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Demander à FixBot
  6. iPad 8 LTE Button Control Cable Replacement, Insert an opening pick: étape 6, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Insert an opening pick: étape 6, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Insert an opening pick: étape 6, image 3 de 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
    Demander à FixBot
  7. iPad 8 LTE Button Control Cable Replacement, Separate the left adhesive: étape 7, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the left adhesive: étape 7, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the left adhesive: étape 7, image 3 de 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
    Demander à FixBot
  8. iPad 8 LTE Button Control Cable Replacement: étape 8, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 8, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 8, image 3 de 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
    Demander à FixBot
  9. iPad 8 LTE Button Control Cable Replacement: étape 9, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 9, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 9, image 3 de 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
    Demander à FixBot
  10. iPad 8 LTE Button Control Cable Replacement, Heat the top edge: étape 10, image 1 de 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
    Demander à FixBot
  11. iPad 8 LTE Button Control Cable Replacement, Separate the top left adhesive: étape 11, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the top left adhesive: étape 11, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the top left adhesive: étape 11, image 3 de 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
    Demander à FixBot
  12. iPad 8 LTE Button Control Cable Replacement, Separate the top adhesive: étape 12, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the top adhesive: étape 12, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the top adhesive: étape 12, image 3 de 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
    Demander à FixBot
  13. iPad 8 LTE Button Control Cable Replacement: étape 13, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 13, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 13, image 3 de 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
    Demander à FixBot
  14. iPad 8 LTE Button Control Cable Replacement: étape 14, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 14, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 14, image 3 de 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
    Demander à FixBot
  15. iPad 8 LTE Button Control Cable Replacement, Heat the right edge: étape 15, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
    Demander à FixBot
  16. iPad 8 LTE Button Control Cable Replacement, Separate the top right adhesive: étape 16, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the top right adhesive: étape 16, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the top right adhesive: étape 16, image 3 de 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
    Demander à FixBot
  17. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: étape 17, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: étape 17, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: étape 17, image 3 de 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
    Demander à FixBot
  18. iPad 8 LTE Button Control Cable Replacement, Heat the bottom edge: étape 18, image 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
    Demander à FixBot
  19. iPad 8 LTE Button Control Cable Replacement, Separate the bottom left adhesive: étape 19, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the bottom left adhesive: étape 19, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the bottom left adhesive: étape 19, image 3 de 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the corner before moving to the next step.
    Demander à FixBot
  20. iPad 8 LTE Button Control Cable Replacement, Separate the bottom adhesive: étape 20, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the bottom adhesive: étape 20, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the bottom adhesive: étape 20, image 3 de 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
    Demander à FixBot
  21. iPad 8 LTE Button Control Cable Replacement: étape 21, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 21, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 21, image 3 de 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
    Demander à FixBot
  22. iPad 8 LTE Button Control Cable Replacement: étape 22, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 22, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 22, image 3 de 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
    Demander à FixBot
  23. iPad 8 LTE Button Control Cable Replacement, Heat the right edge: étape 23, image 1 de 1
    Demander à FixBot
  24. iPad 8 LTE Button Control Cable Replacement: étape 24, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 24, image 2 de 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
    Demander à FixBot
  25. iPad 8 LTE Button Control Cable Replacement: étape 25, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 25, image 2 de 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
    Demander à FixBot
  26. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: étape 26, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: étape 26, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: étape 26, image 3 de 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
    Demander à FixBot
  27. iPad 8 LTE Button Control Cable Replacement: étape 27, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 27, image 2 de 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
    Demander à FixBot
  28. iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: étape 28, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: étape 28, image 2 de 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
    Demander à FixBot
  29. iPad 8 LTE Button Control Cable Replacement: étape 29, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 29, image 2 de 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
    Demander à FixBot
  30. iPad 8 LTE Button Control Cable Replacement: étape 30, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 30, image 2 de 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
    Demander à FixBot
  31. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: étape 31, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: étape 31, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: étape 31, image 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    Demander à FixBot
  32. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: étape 32, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: étape 32, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: étape 32, image 3 de 3
    • Use the flat end of a spudger to pry up the vibration isolator below the SIM card reader.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
    Demander à FixBot
  33. iPad 8 LTE Button Control Cable Replacement: étape 33, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 33, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 33, image 3 de 3
    • Use a pair of tweezers to peel the home button cable away from the rear case.
    • The cable is secured with some light adhesive.
    Demander à FixBot
  34. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: étape 34, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: étape 34, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: étape 34, image 3 de 3
    Polyimide Tape
    $9.95
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
    Demander à FixBot
  35. iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: étape 35, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: étape 35, image 2 de 2
    Demander à FixBot
  36. iPad 8 LTE Button Control Cable Replacement: étape 36, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 36, image 2 de 2
    Demander à FixBot
  37. iPad 8 LTE Button Control Cable Replacement: étape 37, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 37, image 2 de 2
    Demander à FixBot
  38. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: étape 38, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: étape 38, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: étape 38, image 3 de 3
    Demander à FixBot
  39. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: étape 39, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: étape 39, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: étape 39, image 3 de 3
    Demander à FixBot
  40. iPad 8 LTE Button Control Cable Replacement: étape 40, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 40, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 40, image 3 de 3
    Demander à FixBot
  41. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: étape 41, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: étape 41, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: étape 41, image 3 de 3
    Polyimide Tape
    $9.95
    Demander à FixBot
  42. iPad 8 LTE Button Control Cable Replacement, Remove the upper component bracket: étape 42, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Remove the upper component bracket: étape 42, image 2 de 2
    • Carefully peel the LCD buffer tape up off of the upper component bracket.
    Demander à FixBot
  43. iPad 8 LTE Button Control Cable Replacement: étape 43, image 1 de 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
    Demander à FixBot
  44. iPad 8 LTE Button Control Cable Replacement: étape 44, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 44, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 44, image 3 de 3
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    • Remove the upper component bracket.
    • You may need to peel the upper component bracket off of some tape securing it to the logic board.
    Demander à FixBot
  45. iPad 8 LTE Button Control Cable Replacement, Disconnect the rear camera: étape 45, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Disconnect the rear camera: étape 45, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
    Demander à FixBot
  46. iPad 8 LTE Button Control Cable Replacement, Heat the rear camera: étape 46, image 1 de 1
    • Heat an iOpener and apply it to the top-left edge of the iPad's rear for thirty seconds to loosen the rear camera adhesive.
    Demander à FixBot
  47. iPad 8 LTE Button Control Cable Replacement: étape 47, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 47, image 2 de 2
    • Use an opening tool to pry the rear camera out of the rear case.
    Demander à FixBot
  48. iPad 8 LTE Button Control Cable Replacement, Remove the rear camera: étape 48, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Remove the rear camera: étape 48, image 2 de 2
    • Use tweezers, or your fingers, to remove the rear camera.
    Demander à FixBot
  49. iPad 8 LTE Button Control Cable Replacement, Disconnect the button control cable: étape 49, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Disconnect the button control cable: étape 49, image 2 de 2
    Demander à FixBot
  50. iPad 8 LTE Button Control Cable Replacement: étape 50, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 50, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
    Demander à FixBot
  51. iPad 8 LTE Button Control Cable Replacement: étape 51, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 51, image 2 de 2
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
    Demander à FixBot
  52. iPad 8 LTE Button Control Cable Replacement, Remove the volume button bracket: étape 52, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Remove the volume button bracket: étape 52, image 2 de 2
    • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the volume button bracket to the rear case.
    Demander à FixBot
  53. iPad 8 LTE Button Control Cable Replacement: étape 53, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 53, image 2 de 2
    • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the lock button bracket.
    Demander à FixBot
  54. iPad 8 LTE Button Control Cable Replacement: étape 54, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 54, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 54, image 3 de 3
    • Insert the point of a spudger between the rear case and the bottom of the volume button bracket to dislodge it.
    • Remove the volume button bracket.
    Demander à FixBot
  55. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: étape 55, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: étape 55, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: étape 55, image 3 de 3
    • Use the flat end of a spudger to push the volume buttons out of their slots in the rear case.
    Demander à FixBot
  56. iPad 8 LTE Button Control Cable Replacement: étape 56, image 1 de 2 iPad 8 LTE Button Control Cable Replacement: étape 56, image 2 de 2
    • Insert an opening pick between the button control cable and the rear case.
    • Slide the opening pick up toward the lock button to cut the adhesive securing the button control cable to the rear case.
    Demander à FixBot
  57. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: étape 57, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: étape 57, image 2 de 2
    • Remove the button control cable.
    • The lock button will become loose once the button control cable is removed.
    • Upon reassembly, remember to set the lock button back into the its slot.
    Demander à FixBot
  58. iPad 8 LTE Button Control Cable Replacement, Loosen the adhesive: étape 58, image 1 de 2 iPad 8 LTE Button Control Cable Replacement, Loosen the adhesive: étape 58, image 2 de 2
    • Heat an iOpener and apply it to the button control cable for thirty seconds.
    Demander à FixBot
  59. iPad 8 LTE Button Control Cable Replacement, Remove the buttons: étape 59, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the buttons: étape 59, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the buttons: étape 59, image 3 de 3
    • Use a pair of tweezers to grip the upper volume button.
    • Insert an opening pick between the volume control cable and the upper volume button.
    • Peel the volume control cable off of the upper volume button.
    Demander à FixBot
  60. iPad 8 LTE Button Control Cable Replacement: étape 60, image 1 de 3 iPad 8 LTE Button Control Cable Replacement: étape 60, image 2 de 3 iPad 8 LTE Button Control Cable Replacement: étape 60, image 3 de 3
    • Repeat the same process to peel the volume control cable off of the lower volume button.
    Demander à FixBot
  61. iPad 8 LTE Button Control Cable Replacement, Remove the lock button bracket: étape 61, image 1 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the lock button bracket: étape 61, image 2 de 3 iPad 8 LTE Button Control Cable Replacement, Remove the lock button bracket: étape 61, image 3 de 3
    Tesa 61395 Tape
    $8.95
    • Use a pair of tweezers to grip the lock button bracket.
    • Insert a halberd spudger or opening pick between the lock button bracket and the button control cable.
    • Peel the button control cable up and off of the pegs on the lock button bracket.
    • Upon reassembly, apply Tesa tape to reattach the volume buttons and lock button bracket to the button control cable.
    Demander à FixBot
  62. iPad 8 LTE Button Control Cable Replacement: étape 62, image 1 de 1
    • Only the button control cable remains.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 8 Answers community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
239 265 Réputation
1 171 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 947 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 743
