Introduction
Follow this guide to replace the rear camera on your iPad Pro 11" 3rd-gen.
This guide is written with an A2301 (cellular + mmWave) model iPad Pro. If you're fixing a Wi-Fi model, you can still use this guide—there will be some visual discrepancies, and you'll need to skip the steps related to the cellular antennas.
Some photos in this guide show the screen disconnected and fully removed. This isn't necessary for the procedure, so this guide skips those steps. If you wish to remove the screen, follow this guide.
Some photos show the battery connector blocked with two card strips. While this is an optional method, it's more reliable to fully discharge the battery. Ignore this visual discrepancy as you work through the guide.
Ce dont vous avez besoin
Camera module, ambient light sensors, proximity senor, and front microphone
Display cables
Screen magnets
LCD edges
Apply a heated iOpener to the right edge of the screen for two minutes.
Outil utilisé dans cette étape :Anti-Clamp$24.95
Pull the blue handle backward to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Insert a new opening pick in the gap you just created.
Slide the pick along the right edge to separate the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
Leave the pick in to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner below the existing pick.
Slide the pick around the bottom right corner to separate the adhesive.
Apply a heated iOpener to the left edge of the screen for two minutes.
The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
There are flat sections of the frame which require an opening pick to be inserted horizontally.
Insert an opening pick at a 45˚ angle just above the bottom left corner.
Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
Separate the remaining adhesive, making sure to follow the instructions exactly as written.
Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
Slide the pick horizontally and don't insert the pick more than 5 mm.
Use an opening pick to remove any remaining adhesive keeping the screen stuck to the frame.
Grab the top right and bottom left corners of the screen.
Slowly slide the screen towards the bottom right corner to separate it from the frame.
Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
Outil utilisé dans cette étape :FixMat$36.95
Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
One 1.3 mm screw
One 2.0 mm screw
Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
Grip the right edge of the screen and fold it open like a book.
Lay the screen down over the left edge of the iPad.
Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
Two 2.0 mm screws
Three 1.3 mm screws
Use a Phillips screwdriver to remove the three 1.2 mm screws securing the top cable shield.
Apply a heated iOpener to the top cable shield for one minute to soften the adhesive securing it to the logic board.
Insert an opening pick under the top cable shield and gently pry up to separate the adhesive.
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers to disconnect the two antenna cables.
Slide an opening pick under the antenna cables to separate them from the logic board.
Use a Phillips screwdriver to remove the 1.2 mm screw securing the press connector bracket to the logic board.
Use tweezers or your fingers to remove the antenna cable bracket.
Use the flat end of a spudger to disconnect the mmWave flex cable.
Use your Phillips screwdriver to remove the six screws securing the rear camera shield to the frame:
Two 2.8 mm screws
One 1.9 mm screw
One 1.9 mm screw
One 1.2 mm screw
One 1.2 mm screw
Use tweezers or your fingers to lift the right side of the camera shield up.
Slide the shield out horizontally.
Use the pointed end of a spudger to disconnect the wide angle camera cable.
Use the pointed end of a spudger to disconnect the power button and LED cable.
Use the flat end of a spudger to disconnect the LiDAR sensor cable.
Fold the LiDAR sensor cable away from the frame to access the press connectors underneath.
Use the pointed edge of a spudger to disconnect the ultra wide camera cable.
Use the flat end of a spudger to gently pry up and loosen the rear camera module.
Use tweezers or your fingers to grab and remove the rear camera module.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 3rd Gen Answers community for help.
