Aller au contenu principal
Toshiba Satellite C75D Notebook. Part of Toshiba's "budget conscious" C-series of laptops, released in 2013.
14 questions Voir tout
How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
It looks like it's a cable as in Step 10 here: Remplacement du moniteur LCD de l'IBM ThinkPad X41
or in Step 12 here: asus laptop k75vm replacing the broken lcd cable Replacement
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Vue éclatée du Toshiba Satellite A215
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
Image Toshiba Satellite A215
Tutoriel
Difficulté :
Modérée
Image IBM ThinkPad X41 Moniteur LCD
Tutoriel
Difficulté :
Modérée
30 minutes - 1 hour
Image Asus K75VM replacing the broken lcd cable
Tutoriel
Difficulté :
Modérée
25 minutes - 1 hour
Indice 2
2 commentaires:
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
par
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
par
Ajouter une réponse
Marie OKeefe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,746
