I need a replacement battery, where can I buy one?
Where can I buy a replacement battery?
Hi @joshuaheart ,
Here is a link to what I believe is a replacement battery for your player.
If you look at the guide posted by @alphapeaches you will notice that the battery has the following parameters (I think) 3.7V 180mAH 502025.
The 502025 are the dimensions of the battery. This equates to 5.0mm deep x 20mm wide x 25mm long.
You can verify this if you disassemble the unit as per the ifixit guide and view the information written on the battery, as it is not easy to discern from the images in the guide.
It is not a recommendation to use the supplier of the battery shown in the link. It is shown to give an idea of the cost of the battery. You may find other suppliers that suit you better. Just search for 3.7V 180mAH 502025 (if this is the correct value written on your battery)LiPo Battery
I'm not finding any replacement batteries for sale, but I did find one device on ebay they're selling for someone to use as parts. Looks like the battery still works, along with most other components. You might try just transferring the motherboard/battery combo from that one.
As far as actually replacing the battery, do be aware that it's wired directly onto the motherboard. Someone in the comments says it's just a button cell battery, but if you look closely at pictures of it, it sure doesn't look like one. Here's the guide: Eclipse 180G2 MP3 Video Player Battery Replacement
Good luck!
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 17
Total : 159
