Aller au contenu principal
Sorti le 16 septembre 2016, modèle 1778, 1784. Disponible en version 32, 128 ou 256 Go en or rose, or, argent, noir, noir jais et rouge.
20 questions Voir tout
Charge port not working
I have a friend who sent his iPhone 7 plus into Apple because the charge port wouldnt work. He tried different chargers etc.
Apple says the frame is bent, so they wont work on it. The frame isnt bent. Sounds like a cop out to me by Apple.
I ordered a charge port and tested it externally and get nothing. I changed his battery and the phone comes on, so the phone is working. However, the original charge port and new charge port dont work. The strange thing is when the phone is off I can plug in the charge cable and it turns the phone on. So something is working, just not the charging.
iTunes doesnt recognize it, so I cant restore it. Im guessing at this point it's a board level issue. If so, what IC needs to be replaced?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Solution retenue
@israel is correct. the "USB" Charging IC you are looking for is U4001, just make sure the Charging Port FPC Connector or any of the components surrounding it have not been damaged.
Indice 4
1 commentaire:
Thanks. The inside of the phone is in excellent shape. I inspected the components to see if anything else was visibly damaged, but there was nothing. Ill update you when I get it repaired.
par
Réponse la plus utile
You would be looking at the Tristar IC. Let me know if you need help!
Indice 4
2 commentaires:
Thank you. Ill update this thread when I get it repaired.
par
Awesome! Looking forward to your response!
par
Never saw an update, I have a phone right now I am looking at for someone doing the same thing. Battery is fine, not really wanting to do the charging port and order more parts if that’s not the fix. Did you find anything?
Indice 1
1 commentaire:
The company I sent it to couldnt fix it either. I didnt try another company, but it's probably something to do with one of the charge IC's. I dont do board level repairs, so Im unsure. Trying a new charge port without installing it all the way is possible.
par
Zahrealleobey how to fix iphone 7
Indice 0
Ajouter une réponse
Brian Wood sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 5,086
